Intel® C++ Compiler
7957 Discussions
Vectorization with Intel C++ 2022, VS 2022
wmeier
Vectorization using VS 2022
Under Properties, Configuration Properties, C/C++
Code Generation, Enable Enhanced Instruction Set Intel(R) Advanced Vector Extensions 512 (/arch:AVX512)
Code Generation [Intel C++], Intel Processor-Specific Optimization None
This apparently uses the clang vectorizer, which provides optimization diagnostics in the Compiler Optimization Report tab, and in Optimization Notes in Text Editor.
When using a processor-specific option in Code Generation [Intel C++]:
Code Generation [Intel C++], Intel Processor-Specific Optimization Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) for Intel(R) Xeon(R) processors (/QxCORE-AVX512)
This overrides the setting in Code Generation, Enable Enhanced Instruction Set, and apparently uses a different vectorizer than clang.
Using this setting, I no longer get optimization diagnostics in the Compiler Optimization Report tab, nor in Optimization Notes in Text Editor.
Instead, the compiler is generating YAML files. The compiler manual describes a way to view the YAML files using opt-viewer.py, but I cannot find this file in my installation.
What is the best way to get feedback from the compiler regarding vectorization results when using VS 2022 and
wmeier
Thanks for the reply.
1) The first PDF link addresses vectorization with the icl compiler, and has a copyright notice from 2010.  Is there a similar document that addresses vectorization with the icx compiler?
2) Yes, I have enabled the reports using Optimization Diagnostic Level set to Level 3 (/Qopt-report:3).
3) The third link is specific to the Fortran compiler, I am using C++.  The icx compiler does not generate a ".optrpt" file, it generates a ".opt.yaml" file.  Is there any way to review these "yaml" files on Windows?  I have not found the opt-viewer.py in my OneAPI Windows installation.
4) I do not have the "Guided Auto Parallelism" option under Tools in VS 2022.
Abhishek81
Let me check on this and then I will update accordingly.
HemanthCH_Intel
We haven't heard back from you. Could you please let us know if the above links resolve your issue?
Thanks & Regards,
Hemanth
wmeier
No, the links did not resolve my issue.
Please see my original post.  I am looking for a way to get vectorization optimization diagnostics/reporting from icx when using "Code Generation [Intel C++], Intel Processor-Specific Optimization Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) for Intel(R) Xeon(R) processors (/QxCORE-AVX512)".
The compiler create YAML files, but I have no way of viewing those on Windows (opt-viewer.py is not included in the oneAPI directories).
HemanthCH_Intel
>>"but I have no way of viewing those on Windows (opt-viewer.py is not included in the oneAPI directories)."
The opt-viewer.py is not part of the oneAPI directories. You need to download opt-viewer.py externally from the llvm-toolchain(llvm/tools/opt-viewer).For generating an optimization report and how to use opt-viewer.py, please refer to the below link:
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/compiler-reference/compiler-options/optimization-report-options/qopt-report-qopt-report.html
Thanks & Regards,
Hemanth.
HemanthCH_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Hemanth
HemanthCH_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth
