Intel® C++ Compiler
Vectorized code causes SIGBUS/SIGSEGV (icpc 14.0.1, Mac)
Evgeny_E_
I have experienced my program crash because the compiler generates vectorized code where I think it shouldn't. Invoking the code with unaligned input causes SIGBUS or SIGSEGV. One needs to obtain the source code of the Armadillo C++ library version 4.100.1 (http://arma.sourceforge.net/download.html) to reproduce the problem.
Here is the program:
#include <armadillo>
#include <iostream>
int main() {
    arma::Mat<double> A(25, 25);
    std::cout << A.colptr(0) << std::endl << A.colptr(1) << std::endl;
    A.col(1) *= 2.0; // crash here
    return 0;
I am using Intel Composer XE 2013-SP1 [icpc (ICC) 14.0.1 20131010] on Mac OS X 10.8.5 with XCode 3.2.1 to compile like so:
$ icpc -mkl -Iarmadillo-4.100.1/include arma_bug.cpp -o arma_bug -vec-report=6
arma_bug.cpp(7): (col. 14) remark: vectorization support: reference dest_45828 has aligned access
arma_bug.cpp(7): (col. 14) remark: vectorization support: unroll factor set to 4
arma_bug.cpp(7): (col. 14) remark: LOOP WAS VECTORIZED
The crash occurs when invoking a loop in the Armadillo library at arrayops_meat.hpp:839.
    for(uword i=0; i<n_elem; ++i)
      dest *= val;
The compiler makes an assumption that it is safe to vectorize the loop, which is wrong: the dest array can be unaligned. This unaligned access causes the crash. Placing #pragma novector before this loop solves the problem.
I am hoping that someone from Intel could reproduce this and confirm that it is a compiler issue.
Feilong_H_Intel
Hi Evgeny,
I've reproduced this problem.  Will look into it tomorrow.
Feilong_H_Intel
Evgeny,
I've entered this issue to our problem-tracking database.  I'll let you know when I get an update from engineering team.
Evgeny_E_
To follow up, is this by any chance issue DPD200254088 fixed in Composer 2015 beta update 1?
Feilong_H_Intel
Evgeny,
From what I see, the fix is expected to be in beta update 1.
Feilong_H_Intel
15.0 compiler contains the fix for this issue.  FYI.
