Intel® C++ Compiler
7783 Discussions
Verify that both the operating system and the processor support Intel(R) AVX and F16C instructions.
keith_correa
Hello!
I have an application compiled using the /QxAVX compiler flag and on a multi-boot test machine running Windows 2019 Server, Windows 10 and Windows 11, I get the following error when running the application on Windows 11: Please verify that both the operating system and the processor support Intel(R) AVX and F16C instructions.
The same application runs fine on Windows 2019 Server and Window 10 on the same machine.
CoreInfo for the processor is attached. In the attachment, a '*' indicates support and a '-' indicates no support.
It shows that F16C is supported so any idea what could be causing this?
Theshe
AVX requires support from the CPU and also from the operating system.
There is a CPUID flag to check for AVX support by the CPU.
The feature test bit for AVX is #28 in the register ECX, after the CPUID instruction was called with EAX set to 1:
https://en.wikipedia.org/wiki/CPUID#EAX=1:_Processor_Info_and_Feature_Bits
(this alone does not mean the OS actually supports AVX)
To check if AVX support is actually enabled in the operation system, you have to check XCR0, by calling _xgetbv():
https://www.felixcloutier.com/x86/xgetbv
Bit #2 of the XCR0 value indicates that AVX support has been enabled by the OS:
https://en.wikipedia.org/wiki/Control_register#XCR0_and_XSS
MadhuK_Intel
Thank you for posting in Intel communities.
Could you please provide the details of the Intel Compiler, intel OneAPI toolkit version, and Visual Studio version (if you are using it)?
Could you please provide a sample reproducer code and the steps to reproduce your issue at our end?
Madhu
keith_correa
Using this code, I found that usage of XSAVE/XRSTORE were not enabled by the OS. After a lot of digging, I found that the Windows driver "hwpolicy" which loads on boot was disabled from the registry. Changing the Start value to Boot fixed the problem and all is well now. Thanks to all that replied to me.
MadhuK_Intel
>"fixed the problem and all is well now."
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Madhu
