I am using Intel C++ compiler version 12.0.2 and I want to output assembly files that use Intel Syntax. It is currently displaying them in AT&T syntax. I am using ubuntu and I tried icpc -S -masm=intel Radar-Main.cpp it is giving me the following:"icpc: command line warning #10159: invalid argument for option '-m' " I also tried -use-masm=intel, -asm=intel --masm=intel...So I tried like most permutations of the m a s m letters.
Anyone knows how I can do that?
$ gcc -S -msasm=intel -c tstcase.cpp
cc1plus: error: unrecognized command line option "-msasm=intel"
"g++ -S -masm=intel Desktop/parsec-2.1/pkgs/apps/swaptions/src/HJM_Securities.cpp"
and this is part of the file that I got:
HJM_Securities.s
.file "HJM_Securities.cpp"
.intel_syntax noprefix
.local _ZStL8__ioinit
.comm _ZStL8__ioinit,1,1
mov eax, DWORD PTR [ebp+8]
mov eax, DWORD PTR [eax]
mov DWORD PTR [ebp-28], eax
which is clearly intel Syntax. Now I got 2 conflicting answers from both threads which I opened. the first one claimed that ICC linux compiler syntax can be changed to intel syntax and by default in windows it is intel syntax. While here I was told only at&t syntax.
which one is correct?
You didn't say originally for which linux tools you wanted the switch. I agree that it's a little strange for some Intel linux tools to default to intel format and others to provide no option to use that format.
Intel compilerfor Linux does not genrate Intel assembly. You may use gcc for this.
The latest icc compiler version 12.1 supports that feature. The compiler options are -S masm=intel .
> icc -V
Intel C Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.1.256 Build 20111011
// default is to use att syntax
> icc -S hello.c
> more hello.s
main:
..B1.1: # Preds ..B1.0
..___tag_value_main.1: #4.1
pushq %rbp #4.1
..___tag_value_main.3: #
movq %rsp, %rbp #4.1
..___tag_value_main.4: #
andq $-128, %rsp #4.1
subq $128, %rsp #4.1
movl $3, %edi #4.1
..___tag_value_main.6: #4.1
call __intel_new_proc_init #4.1
// use Intel syntax
> icc -S -masm=intel hello.c
> more hello.s
main:
push rbp #4.1
mov rbp, rsp #4.1
and rsp, -128 #4.1
sub rsp, 128 #4.1
mov edi, 3 #4.1
