I have several C and C++ codes where the compiler fails with internal erroror produces incorrect output at run time.
// icc internal error: 010101_2004
struct S { int x; };
void
fn5 (_Atomic struct S p)
struct S s = p;
and
//icc internal error: 04010002_1529
void
f3 (__float128 x)
register __float128 a __asm ("xmm16");
a = -a;
I have quite a few of these, and Fortran ifort as well,but I am not sure this is the best channel to communicate them.
Can anybody look into them?
The following is an example:
Thanks for reaching to us. You can give us details of all of your issues/error, we will reproduce them and if they are really a bug we will update them to our core developer team.
So, coming to your reported internal errors, please give us a small reproducer with the hardware and software details on which you have tried them.
For Fortran errors please post a thread on the Intel Fortran compiler forum https://community.intel.com/t5/Intel-Fortran-Compiler/bd-p/fortran-compiler
Warm Regards,
Abhishek
We have reproduced the "internal error: 010101_2004" and will investigate it.
We would like to have a test case which produces incorrect output at run time to investigate it further.
I've reported those 2 internal errors to the Developers. In the meantime, if you have 19.1 installed, can you try nextgen compiler (icx)?
$ icc t.c -c
t.c(6) (col. 14): internal error: 010101_2004
compilation aborted for t.c (code 4)
$ icx t.c -c
$ icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.2.254 Build 20200623
I just tried icx on both files and they compile fine with return code zero.
Since it works with icx, we don't have a plan to fix this in icc. Can I go ahead and close this case as "won't fix"?
This thread is closed. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
