Intel® C++ Compiler
Very large structs GCC ok, ICC seg fault, simple example.
jkwi
We have a very large structure ~10GB. GCC does not seem to have a problem with it but ICC is seg faulting. I've boiled it down to simple assignment statements. Any ideas?  Files attached. If we don't allocate but declare the structure it works fine. Any problems with Intel allocating large amounts of memory?  We've tried moving things around in the structure definition but it continues to seg fault.
icc -mcmodel=medium -shared-intel -g  test.c -o test
gcc -mcmodel=medium -g test.c -o test
icc: Version 12.1.5.339 Build 20120612
gcc: gcc (GCC) 4.4.6 20120305 (Red Hat 4.4.6-4)
GCC output:
Allocate the grid struct
sizeof of grids 9.393871GB
Address of grids->G2.rain.count 0x7f5d05143190
Address of grids->G2.d0.count 0x7f5d61d35190
Address of grids->G2.Nt.count 0x7f5d96d2d190
Address of grids->G2.dBZm.count 0x7f5f079a0190
G2.dBZ.stdev[ii][jj][kk][ll][mm] = 2.001000
assigned G2.dBZm.count
assigend G2.dBZm.mean
assigned G2.dBZm.stdev
Address of G2.d0.count 0x7f5d61d35190
Going to assign d0.count
assigned G2.d0.count
Going to assign d0.mean
assigned G2.d0.mean
Going to assign d0.stdev
assigned G2.d0.stdev
Successful write
Intel ICC:
Address of grids->G2.rain.count 0x7fc9e070f190
Address of grids->G2.d0.count 0x7fca3d301190
Address of grids->G2.Nt.count 0x7fca722f9190
Address of grids->G2.dBZm.count 0x7fcbe2f6c190
Address of G2.d0.count 0x7fca3d301190
Segmentation fault
bernaske
Hi Sergey,
i have debug the sample ( icc execute ) with gdb, and proof it with valgrind now the segmentation error
is on:
0x400d85 <main+1649>;   movl $0x6,(%rax)
so i have made a dump with objdump an attach the listing, i'm not a pc assembler specialist ( better on Mainframe Assembler ) but i hope
the listing helps a little
best regards
Franz Bernasek
bernaske
Sergey
now the zip file
best regards
Franz Bernasek
SergeyKostrov
Valued Contributor II
Thanks. >>...the segmentation error is on: >>... >>0x400d85
; movl $0x6,(%rax) >>... and in the codes this is: ... grids->G2.d0.count[ii][jj][kk][ll][mm] = ( __int32 )6; ... Let's wait for a response from Mark-sabahi (Intel) since he is already investigating the problem.
SergeyKostrov
I detected another problem with Intel C++ compiler when the struct was declared for automatic allocation and please take a look at compilation outputs: ------ Build started: Project: MemTestApp, Configuration: Release x64 ------ Compiling with Intel(R) C++ Compiler XE 13.0.0.089 [Intel(R) 64]... (Intel C++ Environment) Stdafx.cpp Compiling with Intel(R) C++ Compiler XE 13.0.0.089 [Intel(R) 64]... (Intel C++ Environment) MemTestApp.cpp Linking... (Intel C++ Environment) catastrophic error: Local variable size exceeds supported maximum xilink: error #10014: problem during multi-file optimization compilation (code 1) xilink: error #10014: problem during multi-file optimization compilation (code 1) MemTestApp - 3 error(s), 0 warning(s), 0 remark(s) ------ Build started: Project: MemTestApp, Configuration: Debug x64 ------ Compiling with Intel(R) C++ Compiler XE 13.0.0.089 [Intel(R) 64]... (Intel C++ Environment) Stdafx.cpp Compiling with Intel(R) C++ Compiler XE 13.0.0.089 [Intel(R) 64]... (Intel C++ Environment) MemTestApp.cpp catastrophic error: Local variable size exceeds supported maximum compilation aborted for .\MemTestApp.cpp (code 1) MemTestApp - 1 error(s), 0 warning(s), 0 remark(s) Note: Updated test project ( update 2 ) is attached.
jkwi
FYI. Here is a similar test program using the same structure but in Fortran. Seems to work as expected.
I know this Fortran is using extensions and not strict F95/2003 but we are wedded to some legacy code for now.
ifort: Version 11.1    Build 20100806 Package ID: l_cprof_p_11.1.073
ifort -mcmodel=medium -shared-intel -fpp test.f90
Output:
Address of grids                  601820
 Size of grids            10086592896
Address of grids.G2.rain.count                2DD6F9A0
Address of grids.G2.d0.count                B255B9A0
Address of grids.G2.Nt.count                E75539A0
Address of grids.G2.dBZm.count                8A9619A0
 write some values to grid
 grids.G2.dBZ.stdev(ii,jj,kk,ll,mm) =    2.010000
Address of d0.count               B255B9A0
 Assigned d0.count
 grids.G2.d0.count =            6
 Successful write
SergeyKostrov
>>...Here is a similar test program using the same structure but in Fortran. Seems to work as expected... Do you want me to verify the new test under Windows 7 Professional 64-bit?
SergeyKostrov
>>>>c:\wutemp\memtestapp\Tk-3dpr-hdf5.h(484) : error C2089: '' : 'struct' too large >>>>... >> >>I reported the problem to Microsoft and this is a response: >>... >>...Visual C++ does not handle structures larger than 2GB. This appears to be a known issue... >>... By the way, the problem is not fixed for three years ( 1st time it was reported in February 2010 ).
Mark_S_Intel1
Thank you for the test case. I reproduced the problem and filed a report on this issue.  I will let you know as soon as I get an update from the compiler development team.
SergeyKostrov
>>... I reproduced the problem and filed a report on this issue. I will let you know as soon as I get an update from >>the compiler development team... It is good news, Mark. Thanks. I think limitations on a size of some structure(s) ( especially for automatic allocation ) have to be removed if an application is built for a 64-bit platform. I would also suggest an idea of a dynamic limitation(s) and it could be dependent on a total amount of memory ( physical + virtual ) available on the system.
jkwi
  Mark and Sergey,
  Thank you very much for confirming the issue. I've passed this on to our Admins and they have gone through Premier Support as well.
  We have other test codes that use upwards of 20GB arrays with no issues, reading and writing to all array elements.
  Is the issue related to the size of the structure or the complexity of the structure with many arrays of mixed data types?
  Please give us any indication if there is a short vs. long term fix.
  We have machines with up to 128GB/256GB of physical memory and for us using these large structures is the most efficient way to consolidate our data. The data in the structure ends up in an internally compressed HDF5 file.  In addition, we have applications and libraries written in C, Fortran and mixed language that need to access these large structures.
SergeyKostrov
>>Is the issue related to the size of the structure or the complexity of the structure with many >>arrays of mixed data types? As we can see there is some issue with Intel C++ compiler and it is related to the size of the parent structure when it is greater than ~4GB and it is not related to the complexity of declaration of structures. >>We have machines with up to 128GB/256GB of physical memory and for us using these large structures is >>the most efficient way to consolidate our data. Absolutely agree since that approach is very simple. I hope that your comments about computers with 128GB/256GB of physical memory will be taken into account because we live in times of GigaBytes and TeraBytes, not MegaBytes. As a workaround in case of Intel C++ compiler I would suggest to split the primary structure into a couple of smaller structures and a simple test could verify if the workaround will work.
ama1
Using: icc --version
icc (ICC) 12.1.3 20120212
A similar program to jkwi's with the structure allocated on the stack and my ulimit set to unlimited works. Program attached and output is:
./test_noloop_static
Address of grids.G2.dBZm.count 0x7fffb7f81c40
assigned G2.dBZm.mean
Address of G2.d0.count 0x7ffe12316c40
assigned G2.d0.mean
Successful write
SergeyKostrov
Mark, please try to do a very simple test ( for 32-bit and 64-bit platforms ) and here are source codes: #include "stdio.h" typedef struct tagSmallDataSet { int iData[4][4][4][4][4][4][4][4][4][4]; } SmallDataSet; void main( void ) { SmallDataSet sds; sds.iData[0][0][0][0][0][0][0][0][0][0] = 777; printf( "%d\n", ( int )sds[0][0][0][0][0][0][0][0][0][0] ); } Note: Added '.iData' and now it looks like: 'sds.iData[0]...'. Sorry about it.
SergeyKostrov
>>Using: icc --version >>icc (ICC) 12.1.3 20120212 >> >>A similar program to jkwi's with the structure allocated on the stack and my ulimit set to unlimited works. >>... Unfortunately I don't have a chance to verify it with a 64-bit Intel C++ compiler version 12.1.3. In my tests on a 64-bit Windows platform I used version 13.0.0.089.
Mark_S_Intel1
Sergey,
>>"Mark, please try to do a very simple test ( for 32-bit and 64-bit platforms ) and here are source codes:"
Your test case compiles and runs fine.
--mark
SergeyKostrov
>>>>"Mark, please try to do a very simple test ( for 32-bit and 64-bit platforms ) and here are source codes:" >> >>Your test case compiles and runs fine. Mark, What version of Intel C++ compiler do you use? I received a private email from another IDZ user who confirms the problem with the latest test case. In essence, there is no need in GBs of memory in order to reproduce that problem for N-Dimensional structure ( where N is greater than 5 ). I will also test that simpliest test with Intel C++ compiler version 8.1.038 and all the rest C/C++ compilers I have. Attached is a new test project for Visual Studio 2008 Professional Edition. Intel C++ compiler XE 2013.0.0.089 compiles but executable fails ( an exception is thrown ) and take a look at sources.
SergeyKostrov
Hi everybody, The following compilation error happens when a 26-D struct is declared ( size is 67108864 bytes ) as static and I would consider it as expected error ( a test with a 25-D struct worked ): ...>icl Test.cpp Intel(R) C++ Compiler XE for applications running on IA-32, Version 12.1.3.300 Build 20120130 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. Test.cpp Test.cpp(8) (col. 9): catastrophic error: out of memory compilation aborted for Test.cpp (code 4) You need to use switches that control Heap or Stack commit and reserved values used by the linker (!). #include "stdio.h" typedef struct tagDataSet { // 2^26 = 67108864 - Default limit for 32-bit Intel C++ compiler // 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 __int8 iData[2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2][2]; } DataSet; DataSet ds = { 0x0 }; int main( void ) { ds.iData[0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0] = 77; printf( "%d\n", ds.iData[0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0] ); return ( int )0; } Note 1: In case of automatic allocation use /F compiler switch: /F - set the stack reserve amount specified to the linker Note 2: In case of static allocation of a large struct a heap value ( as larger as possible ) has to be set for the linker and please do your own verifications and tests.
SergeyKostrov
I will do one more test ( with a test case from the previous post ) on a 64-bit Windows 7 Professional with Intel C++ compiler XE 2013 version 2013.0.0.089 and post results.
bernaske
Hi Sergey,
i have compile your sample with the Parallel Studio XE 2013 for Linux Compiler(  icc (ICC) 13.1.0 20130121
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
linux-cuda:~ # icpc --version
icpc (ICC) 13.1.0 20130121
linux-cuda:~ # )  under openSUSE 12.2  64 Bit Linux Kernel 3.4.30 ,  no problem
works , no compile error, no link error , executable runs result  77 was displayed.
#include "stdio.h"
} DataSet;
int main( void )
return ( int )0;
best regards
Franz
SergeyKostrov
Thank you, Franz. As I promised here are results of two tests with Intel C++ compiler XE 2013 on WIndows 7 Professional 64-bit: [ TEST 1 - Intel C++ compiler - 32-bit ] - No problems ..>icl.exe Test.cpp Intel(R) C++ Compiler XE for applications running on IA-32, Version 13.0.0.089 Build 20120731 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. Test.cpp Microsoft (R) Incremental Linker Version 9.00.30729.01 Copyright (C) Microsoft Corporation. All rights reserved. -out:Test.exe Test.obj [ Test Output ] 77 [ TEST - 2 Intel C++ compiler - 64-bit ] - No problems ..>icl.exe Test.cpp Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.0.089 Build 20120731 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. Test.cpp Microsoft (R) Incremental Linker Version 9.00.30729.01 Copyright (C) Microsoft Corporation. All rights reserved. -out:Test.exe Test.obj [ Test Output ] 77
SergeyKostrov
Mark, I'm not concerned about Intel(R) C++ Compiler XE ( 32-bit ) Version 12.1.3.300 Build 20120130 because it was just additional verification. Please keep everybody informed regarding status of the original problem with ~9GB structure. Best regards, Sergey
