I encountered a problem concerning virtual functions and anonymous classes. I'm not sure whether this is due to a compiler bug or just illegal C++ code (see also http://stackoverflow.com/questions/2082339/virtual-tables-on-anonymous-classes). Anyway, the problem only occurs when the program given below is compiled with the C++ Compiler which is part of Parallel Studio 2011 (Version 12.0.0.063, Build 20100721), but it does not occur when using the Intel C++ Compiler for Linux (Version 11.1, 20100806) or GCC 4.5.1. If it's illegal C++ code, I would suggest to let the compiler emit at least a warning.
Kind regards,
Peter
#include
using namespace std;
class base {
public:
virtual void test() = 0;
class foo: public base {
public:
void test() {cout << "foo " << endl;}
class bar: public base {
public:
void test() {cout << "bar " << endl;}
int main() {
class: public foo {} f1;
// b1 is never used, but must exist to produce the error
class: public bar {} b1;
// prints "foo", okay!
(static_cast (&f1))->test();
// prints "bar", wrong!
base* temp1 = static_cast (&f1);
temp1->test();
class foo2: public foo {} f2;
(static_cast (&f2))->test();
base* temp2 = static_cast (&f2);
temp2->test();
Kind regards,
Peter
#include
class base {
public:
public:
public:
int main() {
(static_cast
temp1->test();
(static_cast
temp2->test();
I've created a bug report based on this testcase.
The link you provided http://stackoverflow.com/questions/2082339/virtual-tables-on-anonymous-classes has a slightly different test, icl gives an internal error. I'll also report it as well to get the internal error fixed.
Thanks for reporting.
Jennifer
Updated info on the virtual function issue and the other internal error one. Both are fixed and should be in the next Update 2 release. The issues are DPD200161465, DPD200161467(Internal Error).
Please watch the email notification from Intel Premier Support around end of Jan or early Feb 2011 about the update 2 release. When update 2 is release, our fixes listshould show the issue IDsonhttp://software.intel.com/en-us/articles/intel-composer-xe-2011-compilers-fixes-list/
Jennifer
Jennifer
