Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7701 Discussions
WIN64: 'unresolved external symbol __fastfail referenced in function' error for Debug Qt builds using Windows ICC
sav
Hello, everyone,
For Qt builds using Windows ICC got error:
        if not exist ..\..\lib\Qt5Cored.dll if exist ..\..\lib\Qt5Cored.dll.embed.manifest del ..\..\lib\Qt5Cored.dll.embed.manifest
        if exist ..\..\lib\Qt5Cored.dll.embed.manifest copy /Y ..\..\lib\Qt5Cored.dll.embed.manifest ..\..\lib\Qt5Cored.dll_manifest.bak
        xilink /NOLOGO /DYNAMICBASE /NXCOMPAT /DEBUG /DLL /SUBSYSTEM:WINDOWS /VERSION:5.12 /MANIFEST /MANIFESTFILE:..\..\lib\Qt5Cored.dll.embed.manifest /OUT:..\..\lib\Qt5Cored.dll @C:\Users\test\AppData\Local\Temp\Qt5Cored.dll.4736.250.jom
   Creating library ..\..\lib\Qt5Cored.lib and object ..\..\lib\Qt5Cored.exp
qlogging.obj : error LNK2019: unresolved external symbol __fastfail referenced in function "void __cdecl qt_message_fatal(enum QtMsgType,class QMessageLogContext const &,class QString const &)" (?qt_message_fatal@@YAXW4QtMsgType@@AEBVQMessageLogContext@@AEBVQString@@@Z)
..\..\lib\Qt5Cored.dll : fatal error LNK1120: 1 unresolved externals
jom: C:\libQT-5.12-dev\build\qtbase\src\corelib\Makefile.Debug [..\..\lib\Qt5Cored.dll] Error 1120
jom: C:\libQT-5.12-dev\build\qtbase\src\corelib\Makefile [debug] Error 2
jom: C:\libQT-5.12-dev\build\qtbase\src\Makefile [sub-corelib-make_first] Error 2
jom: C:\libQT-5.12-dev\build\qtbase\Makefile [sub-src-make_first] Error 2
jom: C:\libQT-5.12-dev\build\Makefile [module-qtbase-make_first] Error 2
which relate to recently merged Change #225048.
Reproduced for:
  • builds using Windows ICC with Debug configuration,
not reproduced for:
  • builds using Windows ICC with Release configuration,
  • builds using mingw-w64 and MSVC.
Environment:
It was reported on Qt bugtracker (see QTBUG-68751), and Qt Developers believe it's a compiler bug.
Best,
Alexander
