Hello, everyone,
For Qt builds using Windows ICC got error:
if not exist ..\..\lib\Qt5Cored.dll if exist ..\..\lib\Qt5Cored.dll.embed.manifest del ..\..\lib\Qt5Cored.dll.embed.manifest if exist ..\..\lib\Qt5Cored.dll.embed.manifest copy /Y ..\..\lib\Qt5Cored.dll.embed.manifest ..\..\lib\Qt5Cored.dll_manifest.bak xilink /NOLOGO /DYNAMICBASE /NXCOMPAT /DEBUG /DLL /SUBSYSTEM:WINDOWS /VERSION:5.12 /MANIFEST /MANIFESTFILE:..\..\lib\Qt5Cored.dll.embed.manifest /OUT:..\..\lib\Qt5Cored.dll @C:\Users\test\AppData\Local\Temp\Qt5Cored.dll.4736.250.jom Creating library ..\..\lib\Qt5Cored.lib and object ..\..\lib\Qt5Cored.exp qlogging.obj : error LNK2019: unresolved external symbol __fastfail referenced in function "void __cdecl qt_message_fatal(enum QtMsgType,class QMessageLogContext const &,class QString const &)" (?qt_message_fatal@@YAXW4QtMsgType@@AEBVQMessageLogContext@@AEBVQString@@@Z) ..\..\lib\Qt5Cored.dll : fatal error LNK1120: 1 unresolved externals jom: C:\libQT-5.12-dev\build\qtbase\src\corelib\Makefile.Debug [..\..\lib\Qt5Cored.dll] Error 1120 jom: C:\libQT-5.12-dev\build\qtbase\src\corelib\Makefile [debug] Error 2 jom: C:\libQT-5.12-dev\build\qtbase\src\Makefile [sub-corelib-make_first] Error 2 jom: C:\libQT-5.12-dev\build\qtbase\Makefile [sub-src-make_first] Error 2 jom: C:\libQT-5.12-dev\build\Makefile [module-qtbase-make_first] Error 2
which relate to recently merged Change #225048.
Reproduced for:
- builds using Windows ICC with Debug configuration,
not reproduced for:
- builds using Windows ICC with Release configuration,
- builds using mingw-w64 and MSVC.
Environment:
- Windows 10 x64,
- ICC 2018 Update 3,
- MSVC 2017 15.7.3,
- mingw-w64 x86_64 8.1.0,
- Windows SDK 10.0.17134.12,
- Qt5-dev-de191df84fbdf0f7ddaa2e5d5cb10d4a475a639f.
It was reported on Qt bugtracker (see QTBUG-68751), and Qt Developers believe it's a compiler bug.
Best,
Alexander
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
