Intel® C++ Compiler
7942 Discussions
Warning #1879: unimplemented pragma ignored
SergeyKostrov
Valued Contributor II
Please take a look:
../PrtTests.cpp(2672): warning #1879: unimplemented pragma ignored
#pragma intrinsic ( _ReadWriteBarrier )
Why a fundamental feature is not implemented?
Development Environment:
OS: Windows XP 32-bit
IDE: Visual Studio 2005 SP1
Compilers: Intel C++ / Microsoft C++ / Borland C++ / MinGW / Turbo C++
Sergey
Om_S_Intel
I have reproduced the issue and submitted a report on this to Intel compiler development team. I will update the thread when I have more information on this.
Om_S_Intel
The pragma is implemented in Intel Compiler 12.1.
// tstcase.cpp
#include
# pragma intrinsic (_InterlockedExchangeAdd64)
volatile __int64 electronic_city;
int main()
__int64 somet;
somet = InterlockedExchangeAdd64(&electronic_city, 0);
return 0;
c:\ISSUES\>icl -c tstcase.cpp
Intel C++ Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.1.258 Build 20111011
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
tstcase.cpp
It would be nice if you can provide a testcase to reproduce the issue.
SergeyKostrov
Didyou try to compile your Test-Case when a Warning Level is set to5?
SergeyKostrov
Here are two Test-Cases:
[cpp]// For Sub-Test 1 #pragma intrinsic( _ReadWriteBarrier ) int g_iVariable = 0; // Declared as global // For Sub-Test 2 #pragma intrinsic( _InterlockedExchangeAdd ) volatile LONG g_lVolatileVar = 0; ... // Sub-Test 1 - Verification of _ReadWriteBarrier intrinsic function { ///* #define _USE_READWRITEBARRIER int *piData = NULL; g_iVariable = *piData; #if defined ( _USE_READWRITEBARRIER ) _ReadWriteBarrier(); #endif g_iVariable = 7; // Creates an Access Violation #endif //*/ } // Sub-Test 2 - Verification of _InterlockedExchangeAdd intrinsic function { ///* LONG lInitVal = _InterlockedExchangeAdd( &g_lVolatileVar, 55 ); //*/ } ... [/cpp]
Intel C++ compiler version:
Intel C++ Compiler XE 12.1.3.300 [IA-32]
Intel C++ compiler command line options:
/c /Od /D "WIN32" /D "_CONSOLE" /D "_DEBUG" /D "_VC80_UPGRADE=0x0710"
/D "_UNICODE" /D "UNICODE" /GF /EHsc /RTC1 /MTd /GS /fp:precise /W5 /nologo /ZI /TP
/Qopenmp /Qdiag-disable:111,673
Sergey
SergeyKostrov
Here is a screenshot ( the Warning 1879 is generated in both cases ):
Om_S_Intel
I am still not able to reproduce. I have compiled your testcase without any issue.
c:\forum\U105045>type tst.cpp
#include
#include
// For Sub-Test 1
// For Sub-Test 2
void foo1()
int *piData = NULL;
#endif
//#endif
void foo2()
c:\forum\U105045> icl -c /Od /D "WIN32" /D "_CONSOLE" /D "_DEBUG" /D "_UNICODE" /D "UNICODE" /GF /EHsc /RTC1 /MTd /GS /fp:precise /W3 /ZI /TP tst.cpp
Intel C++ Compiler XE for applications running on IA-32, Version 12.1.1.258 Build 20111011
tst.cpp
SergeyKostrov
Please change /W3 to /W5.
Sergey
Om_S_Intel
SergeyKostrov
Thank you, Om!
Sergey
vbmacher
Hello there, I am facing to similar problem. I am using Boost 1.49 libraries, compiled by Intel compiler 12.1. Within compiling process, the same (several) warnings appear:
[bash]#pragma intrinsic Warning #1879: unimplemented pragma ignored [/bash]
In my code I use the following class:
[c++]template class Interlocked { volatile LONG myValue; public: Interlocked(ArithmeticType val = 0) : myValue(val) {} ArithmeticType operator =(ArithmeticType newVal) { return (ArithmeticType)::InterlockedExchange(&myValue, (LONG)newVal); } ArithmeticType operator ++() { return (ArithmeticType)::InterlockedIncrement(&myValue); } ArithmeticType operator --() { return (ArithmeticType)::InterlockedDecrement(&myValue); } ArithmeticType operator +=(ArithmeticType val) { return (ArithmeticType)::InterlockedExchangeAdd(&myValue, (LONG)val) + val; } ArithmeticType operator -=(ArithmeticType val) { return (ArithmeticType)::InterlockedExchangeAdd(&myValue, (LONG)(-val)) - val; } bool operator ==(ArithmeticType val) const { return ::InterlockedCompareExchange(const_cast(&myValue), (LONG)val, (LONG)val) == (LONG)val; } operator ArithmeticType() const { return (ArithmeticType)myValue; } /** * Sets the newVal iff the original value was equal to comparand; leaves the original value otherwise. * Returns true iff the exchange was actually performed. */ bool compareExchange(ArithmeticType newVal, ArithmeticType comparand) { return ::InterlockedCompareExchange(&myValue, (LONG)newVal, (LONG)comparand) == (LONG)comparand; } }; template < > Interlocked::operator bool() const { return operator ==(true); }[/c++]
In other class I define "Interlocked" variable like this:
[bash]Interlocked myIsShutdownRequested;[/bash]
This variable is accessed in multi-threaded environment. Sometimes in the place where the variable is accessed I get "AccessViolation" exception.
Please, do you have an update from Intel development forum? Thank you very much!
SergeyKostrov
Please take a look at a Post #7. Some time ago Om submitted a report.
Michael_R_Intel5
Be aware that even though the Intel compiler does not currently implement this pragma it doesnt usually mean there will be a problem in your code. The compiler will still recognize the intrinsics (such as _ReadWriteBarrier and _InterlockedExchangeAdd64) and expand or call them as needed. So for most users this warning when related to #pragma intrinsic is nothing to worry about.
