Intel® C++ Compiler
7956 Discussions
Warning code for catching semicolon after a while loop
nielsen__jan_kampman
Hello all.
I wonder if there is a warning code which
flags that there is placed an unintentional semicolon
after a while loop.
while(condition);
  Body
I have already sought after the warning code my
self in the documentation and have written
code trying to provoke a warning but without
any luck. I have enabled all warnings but to
no avail. The compiler is Intel C++ 2019.
If there is no warning code for this, my vain
hope is that Intel will in time add an warning
for this, because I cannot be the first or the last
to have this kind of bug.
Please be kind it is my first posting in this
forum. Hope my attempt at writing in English
is understandable.
Best regards
Jan, DK.
jimdempseyatthecove
while(condition); is a valid syntax for C/C++. This said, there are several "lint" programs available that flag potential problems in coding. In this case enforcing:    while(condition) continue;
Perform a Google search on "C++ lint tools" to locate potential tools for you to use.
Jim Dempsey
Hello Jim
Thank you for your answer.
I am reading Microsofts "Writing solid code" By Steve Maguire.
I know this is a valid syntax and I could buy a affordable Lint, but I feel
it is something the compiler should be able to handle. So far as I know
it is a common mistake just like : if (Number = 0) instead of if (Number == 0)
Basically the idea is to warn about those constructs in the syntax that is valid
but rarely used and if you really want to, you could write : while(condition); {}
to supres the warning(the books example). One of the points is to let the compiler
find errors, that are not illegal but introduces logical errors, during compilation - which is an idea I find useful.
Best regards
Jan
jimdempseyatthecove
Consider if(Number = OtherNumber), or if(result = expression)
In the first case, the equate may be as intended. In the second case equate is likely intended, as the compiler cannot disambiguate with if(exitValue = expression).
This said, I can see it could be handy to have a -warn:ambiguous_if, -warn:ambiguous_while
IMHO, the proper ways are:
while(condition) {};     // semicolon to right of {}
Jim Dempsey
Hello Again
There is a warning by default(Visual Studio 17, C++ 2019)
for if (Number = 0). I have chosen to treat it like an error with
the help of these options : /Qdiag-enable:187  /Qdiag-error:187
I have managed to generate automatically a list
of all warnings, but I have not found the right search word
to locate the warning for while(condition);
Best regards
Jan
jimdempseyatthecove
The while(condition); is not an error in syntax.
Consider a multi-threaded scenario where while(!Done.load()); is used as a barrier.
In the single threaded situation where while(condition); is a programming error, this will quickly evident when debugging the program.
Jim Dempsey
