Is there a way to disable the nullptr check in placement new?
As of C++17 the nullptr check is no longer required: "If the standard placement allocation function returns a null pointer, which is possible if the user passes a null pointer as the argument, the behavior is undefined. (since C++17)", from http://en.cppreference.com/w/cpp/language/new
The change to C++17 was made specifically to remove the nullptr check: "This test is unnecessary overhead; it should be the user's responsibility to ensure that a null pointer is not used in these forms of placement new, just as for other cases when a pointer is dereferenced.", from Defect Report 1748 at http://www.open-std.org/jtc1/sc22/wg21/docs/cwg_defects.html
I am using the Intel C++ 64 compiler for Windows, version 18.0.0.124 Build 20170811. Among the things that I have tried are the command line option /Qstd=c++17, and using the __assume statement as a hint to the optimizer that the memory pointer is not a nullptr. Here is a snippet from the assembler output showing the nullptr check:
;;; __assume( nullptr != MemoryPointer ); ;;; BaseClass* Pointer = new( MemoryPointer ) MyClass(); test rbx, rbx je .B1.5 .B1.3:: mov rax, QWORD PTR [__$U2a.0.168] mov QWORD PTR [rbx], rax .B1.4:: mov rcx, rbx jmp .B1.6 .B1.5:: xor ecx, ecx .B1.6::
The command line I used:
icl /FAs /Os /Qstd=c++17 test.cpp
The source code for test.cpp:
#includeclass BaseClass { public: virtual void Write() { std::cout << "BaseClass"; return; } }; class MyClass: public BaseClass { public: virtual void Write() override { std::cout << "MyClass"; return; } }; void* GetMemoryPointer() { return new int[1000]; } int main() { void* MemoryPointer = GetMemoryPointer(); __assume( nullptr != MemoryPointer ); BaseClass* Pointer = new( MemoryPointer ) MyClass(); Pointer->Write(); delete[] MemoryPointer; return 0; }
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
