Now, I agree that I am asking for trouble, but I find the following failure weird. The following code:
#include <iostream>
using namespace std;
template<typename ... Pack>
void weeble(Pack ... rest, double x) {
int y[] = {rest...};
for (int i = 0; i < sizeof(y)/sizeof(*y); ++i) cout << y << " ";
cout << x << endl;
int main () {
weeble(123,456,789,3.1416);
When compiled with icpc -std=c++11 and the beta compiler, gives:
junk.cpp(12): error: no instance of function template "weeble" matches the argument list
argument types are: (int, int, int, double)
I cannot find anything forbidding it in C++11, and it is parsable (in theory).
If function parameter packs must be final, why did I not get an error message when the function was parsed?
Nick,
I can reproduce the problem with the actual compiler Intel® C++ Composer XE 2013 SP1. Variadic templates should be supported. However, g++ 4.8 doesn't compile too with similar error.
Let me check.
Regards, Hubert
The gcc people pointed me at [temp.deduct.call], which indicates that a compiler is at least allowed to fail to resolve the match. Whether that means it is required to ignore it depends on your interpretation of the wording of the standard (like so much else in C++ - sigh).
But, as with gcc, what would be useful would be a warning on the template function declaration. I knew that I was pushing the boundary, but couldn't find anything that actually forbade that - the gcc person could, though.
If you look at the bottom of this paper (Issue 818):
http://www.open-std.org/JTC1/SC22/WG21/docs/papers/2010/n3079.html
You will see the restriction about funcion parameter packs being in the
final argument has been lifted.
However, this requires that a user explicitly list the arguments in
the parameter pack (template deduction will not work).
Your example is changed below. This will compile with g++ and icpc.
Judy
#include <iostream>
cout << x << endl;
int main () {
weeble< int,int,int>(123,456,789,3.1416);
return 0;
Thank you. Unfortunately, that's not really a reasonable specification for my purpose :-( I don't think that C++ can do what is wanted.
