This is a section of code that's supposed to calculate the number of monomial terms necessary to represent a polynomial in x and y, where the polynomial order along x and y can be different. This is about as pared down as I could get it and still recreate the bug.
When compiling this code with icpc and the compiler flags -O0 or -O1, I get the correct output (cnt=3), whereas if I compile with -O2 or -O3, I get a wrong answer (cnt=2).
I worked around this issue by defining MAX() as a function instead of a macro, but I'm posting this because I'm not really sure why this happened. If I did something wrong here, I don't see it.
I'm running this on CentOS 5.5, and "icpc --version" yields
[cpp]#include// note defining MAX as a macro (as opposed to // a function) is necessary in order to recreate // the bug #define MAX(X,Y) (((X) > (Y)) ? (X) : (Y)) using namespace std; int main(int argc, char **argv){ int N=1; int *xOrder=new int ; //note: xOrder and yOrder must be int *yOrder=new int ; // be arrays in order to recreate the bug for (int i=0;i =1; yOrder=1; } for (int i=0;i ,yOrder); for (int o=0;o<=order;o++){ for (int ii=0;ii<=o;ii++){ int oX=ii;int oY=o-ii; if (oX>xOrder || oY>yOrder) continue; if ((oX+oY)>MAX(xOrder,yOrder)) continue; // note: no comments can be in this section if we want to recreate // the bug //cout << i << " " << cnt << " x^" << oX << " y^" << oY << endl; cnt++; } } // if xOrder==yOrder==1, cnt should equal 3 cout << " cnt=" << cnt << endl; } delete [] xOrder; delete [] yOrder; return 0; } [/cpp]
[bash]icpc -o bug_test_rel -O3 intel_bug_test.cc icpc -o bug_test_dbg -g -O0 intel_bug_test.cc[/bash]
[bash]icpc (ICC) 11.1 20090827 Copyright (C) 1985-2009 Intel Corporation. All rights reserved. [/bash]
I get the correct answer. I am using FC11 and icc 11.1.072.
There were bugs in the scoping of new[] and the like in those versions. Note that the good versions of 11.1 were issued over a year later than the one quoted.
I'm running 11.1.056. I didn't realize this wasn't a "good version". I'll make sure to upgrade to the current version.
