Intel® C++ Compiler
7782 Discussions
What is "gcc compatibility mode" and how to disable it?
Andreas_D_1
I am - so far - quite unsuccessful in using icpc 2016 while making boost 1.59.0. I did manage to compile a helloworld program BTW.
I am using Linux Mint 17.3
My question is: icpc shows
 ~ $ icpc -v
icpc version 16.0.0 (gcc version 3.2.0 compatibility)
What does the "compatibility mode" mean? It seems that when building bjam in order to install boost 1.59.0 I get errors because "gcc is too old" as they say over in the boost mailinglist. As a matter of fact, my gcc / g++ are version 4.8.4!
I didn't find anything useful when googling..
What's wrong? Thanks a lot in advance for any hint!
Andreas
Judith_W_Intel
The icc driver goes a "gcc -v" and from there tries to figure out the version number of GCC.
If it can't figure it out based upon the expected version string then it defaults to the earliest version supported (in this case gcc 3.2.0).
You can override that with the -i_gcc-version=versionnumber command line option where versionnumber would be 484 in your case.
Judy
TimP
Black Belt
According to the reply Judith gave, it looks like you have a problem with the path settings for your installed gcc in the shell where you run icc.  I thought it would be g++ -v, but if that doesn't agree with gcc -v, that also is a problem.
Judith_W_Intel
I'm guessing he's using an unsupported version of GNU and the version string when you type in gcc -v is different than the one you see on Red Hat, Fedora, etc. and therefore our driver is trying to parse it but can't figure it out.
What does gcc -v say on a Linux Mint machine? On a Red Hat machine it says:
sptxl15-145> gcc -v
Using built-in specs.
Target: i686-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre --enable-libgcj-multifile --enable-java-maintainer-mode --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --disable-libjava-multilib --with-ppl --with-cloog --with-tune=generic --with-arch=i686 --build=i686-redhat-linux
Thread model: posix
gcc version 4.4.4 20100726 (Red Hat 4.4.4-13) (GCC)
sptxl15-146>
Andreas_D_1
Thanks for answering!
I am sorting this out with Patrick in a parallel thread ("Linux Mint: Unsupported?") but here we go
# g++ -v
COLLECT_GCC=g++
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.8/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.8.4-2ubuntu1~14.04' --with-bugurl=file:///usr/share/doc/gcc-4.8/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.8 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.8 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libmudflap --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.8-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04)
# gcc -v
COLLECT_GCC=gcc
Thread model: posix
The compilervars.sh script complained about some "daalvars" - maybe we continue over there?
I guess Judy has answered my initial question here, - many thanks!
Andreas
