Intel® C++ Compiler
7957 Discussions
What's the best way to sum up values in __m128 ?
missing__zlw
It seems to me a very common operation.
_mm128 xx which contains values (xx3, xx2, xx1, xx0), all are in float.
and I would like to do xx0 + xx1 + xx2 + xx3
right now, I can use :
xx = _mm_hadd_ps(xx, _mm_set_zero); // to get (0, 0, xx3+ xx2, xx1+xx0)
xx= _mm_add_ss(xx, _mm_shuffle_ps(xx,xx, _MM_SHUFFLE( 0, 0, 0, 1 )) );
_mm_store_ss(&temp,xx);
Another way :
xx= _mm_add_ps(xx, _mm_movehl_ps(xx, xx));
xx= _mm_add_ss(xx, _mm_shuffle_ps(xx, xx, 1));
_mm_store_ss( &temp, xx );
Is there a better way? This seems a very common operation. Any plan to make it native?
Also, how about sum up numbers in more than one registries?
jimdempseyatthecove
Use hadd twice with same register for both sources and same register for destination
// xx = { xx3, xx2, xx1, xx0 }
xx=_mm_hadd_ps(xx,xx);
// xx = {xx3+xx2, xx1+xx0, xx3+xx2, xx1+xx0}
// xx = {xx2+xx3+xx1+xx0, xx3+xx2+xx1+xx0, xx3+xx2+xx1+xx0, xx3+xx2+xx1+xx0}
The other sums are superfluous (but do not add additional overhead)
Note, if you are on an older processor, try to insert a load or store or non-SSEinstruction(s) between the hadd's.
Jim Dempsey
missing__zlw
Thank you for your response. Isn't mm_hadd_ps more expensive than the _mm_add_ps? Although I didn't find out exactly how much more expensive it is.
Brandon_H_Intel
What's "best" likely depends on what architecture you're targeting. For example, if I have a function like:
[cpp]float foo(float in[4]) {
   return __sec_reduce_add(in[:]);
}[/cpp]
(Note I'm using Intel Cilk Plus array notation here to do the summation)
For the default Intel SSE2 (i.e. icc -S -c test.c), the compiler in Intel C++ Composer XE Update 2 generates:
movups (%rdi), %xmm0 #2.11
movaps %xmm0, %xmm1 #2.28
movhlps %xmm0, %xmm1 #2.28
addps %xmm1, %xmm0 #2.28
movaps %xmm0, %xmm2 #2.28
shufps $245, %xmm0, %xmm2 #2.28
addss %xmm2, %xmm0 #2.28
ret #2.11
For Intel SSE4.2 (icc -xSSE4.2 -S -c test.c), I get:
haddps %xmm0, %xmm0 #2.28
ret #2.11
