Dear all,
Recently I am trying to compiler some code by Intel C++ Compiler XE 13.0, the code is somewhat like the follows:
for(uint i=0; i<skeleton.size(); i++) {
for(auto &entry : skeleton) {
action(i, entry.vid, entry);
when compiling by Intel C++ Compiler XE 13.0, the following error displayed:
Error 17 error : cannot deduce "auto" type (initializer required)
I got to know that this new feature is not supporttd by latest Intel C++ compiler. When could Intel C++ compiler support this feature?
Zhanghong Tang
Greetings,
As Intel's support person said recently, C++11 is the main goal, though, (IIRC it was Jeniffer) said thay cannot comment details for future Intel's plans.
PS: I am waiting impatiently for new release, since in recent one /MP switch under Windows is broken, so I'd like to have knowledge of the timeline, but as she said, they cannot provide comments about this...
Dear Dr. Sergey Kostrov,
Thank you very much for your instructioin, this option works for my issue.
Zhanghong Tang
Yes the "auto" keyword and c++11 range based for loops (which is what this code is using) should be supported in C++ 13.0 if you use the option to turn on c++11 (-std=c++11 on Linux and /Qstd=c++11 on Windows).
Judy
Dear Dr. Sergey Kostrov and Judith Ward,
Thank you very much for your kindly reply. I tested and found that both two options /Qstd=c++0x and /Qstd=c++11 are OK for me. Could you please tell me what's the difference between these two options?
Zhanghong Tang
The effect of those options should be identical. c++0x was chosen by gcc for early development; after the standard was confirmed, c++11 was recommended as the spelling for the future.
Dear Dr. Timp,
Thanks again for your kindly explaination.
I suggest that this option be turned on by default.
Zhanghong Tang
Turning it on by default would break compatibility with the Microsoft compiler. We only enable those c++11 features by default which are already implemented by the reference Microsoft compiler on the user's system.
