Intel® C++ Compiler
Where is the sincos function?
jpanta
I was sure that this is supported in older version but whenever I use a sincos function now (sincos(float v,float *sinv,float *cosv)), I get an undefined function error by the compiler.
Is it really dropped?
Thank you.
Richard_A_Intel
It may be worth knowing that the Intel compiler will automatically generate  __svml_sincosf8..() when a sin() and cos() is used on the same value.  This optimization happens on O2 and O3 and does not need to be explicitly programmed in the source.
TimP
Black Belt
I'm guessing that you are using a linux or MAC compiler and relying on C++ support in glibc or MSVC library.  Your man page on sincos and sincosf ought to discuss the supported ways of calling the function directly.
If I'm guessing wrong, a little more information from you would be helpful, such as the exact wording of the error.
I think standard compliant use of cosf() and sinf() may be more reliable, Compilers look for opportunities to combine them into a single sincos call, possibly a short vector version.
jpanta
Nop, I am talking about Visual Studio + XE Composer 15. I thought that sincosf was a library function (not coming from MSVC library, it is not available there) since I had this working with older compiler (11.1 series). But... I may be wrong and had it somewhere defined myself that I overlooked.
TimP
Black Belt
MSDN describes sincosf but C++11 has changed implementation of some forms of mixed data type math functions, so it's probably better to adhere strictly to what is described in documents.  I wouldn't count on not specifying /Qstd=c++11 as a way of retaining the older interpretation of math functions.
jpanta
Great, thank you for the explanation.
Bernard
Black Belt
 As described in MSDN sincos is part of DirectX HLSL intrinsic functions.
SergeyKostrov
Valued Contributor II
>>...I thought that sincosf was a library function (not coming from MSVC library... I'd like to inform you that 'sincos' function never was a part of CRT library ( C Run-Time ). It is possible that MKL library is used in your software development environment, or some another 3-rd party library is linked.
Richard_A_Intel
TimP
Black Belt
RICHARD A. (Intel) wrote:
It may be worth knowing that the Intel compiler with automatically generate  __svml_sincosf8..() when a sin() and cos() is used on the same value.  This optimization happens on O2 and O3 and does not need to be explicated programed in the source.
I alluded to this in #2, without specifically mentioning the ICL options.    If options such as /fp:source are set, /Qfast-transcendentals would need to be set as well.
jpanta
Thank you all for the clarifications.
