Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7694 Discussions
Where is the x32 ABI compiler libraries?
Yuandong_W_Intel
I am using icc19.4 on ubuntu18.
I want to use -mx32 option to generate some Linux x32 ABI object files and link the x32-compatible libraries (libimf.so and libirc.so).
But I didn't found the x32-compatible libraries in the directory icc19.4/compiler/lib.
So how to do it?
GouthamK_Intel
Hi Yuandong,
We verified with icc 19.1 version in ubuntu 18.04 and we are able to find libimf.so and libric.so files in "/opt/intel/inteloneapi/compiler/2021.1-beta04/linux/compiler/lib/intel64_lin/libimf.so" and "/opt/intel/inteloneapi/compiler/2021.1-beta04/linux/compiler/lib/intel64_lin/libirc.so"  respective paths.
As you have mentioned that you are using icc19.4, whereas the latest version of icc is 19.1. Please recheck the icc version which you are using and let us know.
Goutham
Vladimir_P_Intel2
did you check that x32 is supported? I see -m32 and -m64 options there.
Vladimir
Yuandong_W_Intel
Vladimir
I see it is supported on previous documentation. Not sure about current version.
https://software.intel.com/en-us/node/628948
GouthamK_Intel
Hi Yuandong,
We verified that -mx32 flag is not supported in the current icc version (19.1).
Can you please let us know which version of icc you are using?
you may also try using -m32 option and let us know if your issue is resolved.
Goutham
Yuandong_W_Intel
Kuncham, Goutham Kalikrishna Reddy (Intel) wrote:
Hi Yuandong,
Goutham
Hi, Goutham.
I'm using icc19.4 so it is also assumed x32 not supported.
I must use x32 there, so I'm trying other way.
Anyway, thanks for your help.
Viet_H_Intel
The -mx32 is supported in Bi-Endian compiler, not in PSXE.
Viet_H_Intel
Let us know if this is still an issue. Otherwise, we will close it.
Viet_H_Intel
We will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Thank,
