One feature of the C++ 0x is the r-value reference. We're working to support it. But we do not have a timeline for it.
Such feature will not be in 11.x branch, but a new major release. So it unlikely will be available before VS2010.
If your program does not make use of the other new language features of VS2010, you can start porting with 11.1. Porting is not just like a switch, may take some time. ALso if you found any feature our 11.1 does not support, let us know and so we can get it into our next version - if time allows.
Jennifer
Jennifer
Hi Jennifer,
Just checking in on the status here with the 11.2 release. Do we know if it is coming about the same time as Visual Studio 2010?
Any movement on C++0X features? It will change how I write code now to prepare for it.
In particular, here are a few of the things already in GCC:http://gcc.gnu.org/gcc-4.5/cxx0x_status.html
[cpp]templateauto myfunc(T t) -> decltype(t + t) { return t+t; }[/cpp]
If you are giving feedback on order of implementation for these, I would give these as my ordered list of interests.
Thanks so much, and thanks again for such a great compiler.
Sorry I missed your posting.
No, there will be no 11.2 release. The next major release is 12.0. Some of the C++0x features will be included in 12.0. The 12.0 is still under development. I do not have a date for it.
But you will know when it's released. I will post a big news here. If you're registered to Intel Premier Support, you will get an email notification about it.
A note for VS2010 support, we do not support beta OS or VS. After VS2010 released we will support it in a later time, but it will take some time though.
btw, I've sent your list with 4 features to our engineering team.
Thanks for providing the detail info.[cpp]Alternative function syntax... something like.... templateThe amount of template meta-programming required to get around this is enormous (and often at the mercy of potential compiler bugs. For example, I postedhttp://software.intel.com/en-us/forums/showthread.php?t=73680for the engineering team as a difference with GCC. This likely wouldn't be a problem if alternative function returns were supported).auto myfunc(T t) -> decltype(t + t) { return t+t; } [/cpp]
