Intel® C++ Compiler
7956 Discussions
Which is more precise, "-mp1" or "-prec-div -prec-sqrt"?
maverick6664
Title says it all. Which is precise when sse,sse2,sse3 is enabled in icc 9.0/9.1? IMHO they look the same in concept...
Thanks in advance!
Message Edited by maverick6664 on 05-02-200607:22 AM
TimP
-mp1 includes the effect of -prec-div -prec-sqrt. Either way, you require the compiler to use the fully accurate instructions for divide and sqrt().
maverick6664
Thank you for your reply.
Then how about replacing -mp1 with "-prec-div -prec-sqrt"? Are they the same? Reading the manual, I cannot see the difference between these two. But it sounds like -mp1 performs NaN comparison closer to (or compliant with?) ieee754 while "-prec-div -prec-sqrt" doesn't. Then they are different. I noticed -mp1 option is significantly faster than -mp option. So I want to know the behaviour of -mp1.
I'm eager to know this because I'm using icc/ifort(?) in scientific math program (scilab).
regards,
-Tetsuji
Message Edited by maverick6664 on 05-02-200610:11 AM
TimP
You could set the additional option -# and see the expansion in terms of internal options for your option choices. One would expect that -mp1 makes more settings conservative than simply the divide and sqrt().
If you are looking for more frequent IEEE compliance on NaN handling, you should consider the -fp-model options. -fp-model precise treats parentheses similar to -mp, but does not promote expressions to long double, as -mp does.
maverick6664
ok, thanks! I forgot -# option!
regards,
-Tetsuji
