Greetings,
icpc (ICC) 16.0.1 compiler had "-fast" option which was expanded to "-xHOST -O3 -ipo -no-prec-div -static -fp-model fast=2" according to the manual.
However, new compiler icpc (ICC) 2021.2.0 does not have this alias. What is the reason for deprecation?
Thanks in advance
Seems like a bug in our help option. It has been missing since 19.0. AFAIK, -fast is still supported. If we plan to deprecate it, it will be informed.
You can see the list of deprecated options by "icc -help deprecated"
The -fast option is available in the ICC 2021.2 version.
Example Usage: icpc -fast file.cpp
Please let us know if you face any issues.
Rajesh.
Hi Rajesh,
I looked through `icpc --help` output and haven't found "-fast" option while "-Ofast" is still there. Looks like it is simply missing from the manual, because it seems to add "-static" when I use "-fast". Can you confirm? Also, is there some specific reason why it is missing from the help string, is it considered deprecated?
>>It seems to add "-static" when I use "-fast".
As per documentation, -fast option includes -ipo, -O3, -static, -fp-model fast=2 options.
>>Is there some specific reason why it is missing from the help string
We are checking it internally and will get back to you.
Rajesh.
Since you have accepted the solution. Let us close this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
