How do I do the equivalent of -Wuninitialized on Windows?
Also I would like to make the usage of unitialized and error. Can I do that?
Should be:
/Qdiag-warning:592
Although it looks like this warning is enabled on Windows by default so I think the above is unnecessary.
If you want it to be an error use /Qdiag-error:592.
Judy
/check includes /check:uninit (a warning) by default, but otherwise it's not on by default. Note the colon required on Windows, not on linux.
The /check:uninit option is a bit different -- That enables runtime checking of uninitialized variables, not compile time diagnostics.
So it's not the equivalent of -Wuninitialized.
Judy
To me it seems that /Qdiag-error:592.do not work. Even though I had an unitialized variable no warning or no error was displayed. Below is my compile line.
icl -DCALL_CPU_INTEL_P4 /Oa /DSYSTHREADING=1 /DSYSPTHREAD=1 -DBLDTOOL_INTELC -DWIN64X86=1 -D_CPU_GENERIC_ /D_CRT_SECURE_NO_DEPRECATE /Qvc9 /Qlocation,link,"c:\Program Files (X86)\Microsoft Visual Studio 9.0\VC\bin" /W1 /Wcheck /Qdiag-error:592 /GF /DSYSRESTRICT /Qrestrict /Qprec_div /Qdiag-disable:1572,177 -DSYSMT /MTd /ZI /debug:minimal /Ge /Ob0 /Qfp-stack-check /Zi -DSYSRELEASE=10 -DSYSDEBUG=10 -D_MOSEKDEV=10 -DCCVERSION=15.0.1 /Isrc\basic /Isrc\cpub /Isrc\dualize /Isrc\homo /Isrc\kfac /Isrc\lalib /Isrc\lu /Isrc\math /Isrc\misc /Isrc\netopt /Isrc\network /Isrc\optimize /Isrc\order /Isrc\pivot /Isrc\prslv /Isrc\simplex /Isrc\temp /Isrc\thread /Isrc\cmio\extern /Ibld\bogense\debug\default\intelc-15.0.1\src\ivec /Isrc\lalib /Isrc\lalib\common /c src\math\spchol.c /Fobld\bogense\debug\default\intelc-15.0.1\bin\runchol-objs\spchol.obj Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.148 Build 20141023 Copyright (C) 1985-2014 Intel Corporation. All rights reserved.
Can you please provide a small code sample showing the use of the uninitialized variable?
thanks
Judy
The example below works fine like Judy mentions, so a test case showing the problem is needed.....
%type uninit.cpp
#include <stdio.h>
int main()
int x;
printf("%d\n", x);
return 0;
%icl uninit.cpp
uninit.cpp
uninit.cpp(6): warning #592: variable "x" is used before its value is set
printf("%d\n", x);
Microsoft (R) Incremental Linker Version 12.00.30723.0
Copyright (C) Microsoft Corporation. All rights reserved.
-out:uninit.exe
uninit.obj
%icl /Qdiag-error:592 uninit.cpp
uninit.cpp
uninit.cpp(6): error #592: variable "x" is used before its value is set
printf("%d\n", x);
I agree it works on your example. I tried the capabilities on my source and it did not seem to work. Maybe I did something wrong.
I will get back if I can produce an example where it does not work.
Sure, thanks for letting us know. If you're able to get a reproducer that will be great as it'll be interesting why it doesn't in your environment. That said, you can use the -P option to create a .i (pre-processed) file and attach to this issue if you're able to create a test reproducer.
_Kittur
Any luck in creating a test reproducer?
You do not discover that b is uninitialiazed for c>1. Maybe that is too tricky for you discover. #include <stdio.h> void test(int c) { int b=0; printf("c=%d\n",c); if ( c>1 ) { int b=1; printf("pelle\n"); b += 2*c; } else { printf("polle"); b += c; } printf("b=%d\n",b); } int main(int argc,char *argv[]) { test(atoi(argv[0])); }
Are you sure you posted the right example? It looks like the b inside test() is unconditionalized initialized to 0 at the top of test().
And the local b inside the first if is initialized to 1. There's no declaration of b without an initialization.
Judy
You totally right. I will get back if I find an example.
That's correct @Anderson. I just tried the example as well and couldn't reproduce. Thanks for trying and getting us a test reproducer. It'll be an interesting case if we can reproduce the issue, appreciate much.
_Kittur
