Dear Intel Compiler Experts,
An issue making a project impossible to link on certain machine setup is blocking us at the moment on Mac OS.
To explain the context, the project is a dynamic library composed of one static library compiled by ICC and other files compiled and linked (with this static lib) by the Apple Compiler. On certain computers, the compilation is fully working with XCode 5.1.1 and ICC15, but on some others not. The exact same issue happens also with XCode 7.2 and ICC16.
The issue is the following one:
xilibtool: executing 'libtool'
error: libtool: more than one: -syslibroot option specified
If we add the '-v' option to the XCode Parameter 'OTHER_LIBTOOLFLAGS' we are now able to see more about this issue. Also we did the test on another machine where the issue was not happening. In both cases presented here, we are using ICC15 + XCode 5.1.1.
* Build with a MacPro with Mac OS X 10.10.5 with installed ICC15 and ICC16 (Fail)
libtool \
-static \
-arch_only \
i386 \
-syslibroot \
/Developer/Xcode5.1.1/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk \
-L/ [The *.a of the library compiled with ICC]
-o \
-L/usr/bin/icpc-15.0-base/compiler/lib \
-L/usr/lib \
-syslibroot \
/Developer/Xcode5.1.1/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.8.sdk \
[The *.o files]
/usr/bin/icpc-15.0-base/compiler/lib/libimf.a \
/usr/bin/icpc-15.0-base/compiler/lib/libsvml.a \
/usr/bin/icpc-15.0-base/compiler/lib/libirng.a \
/usr/bin/icpc-15.0-base/compiler/lib/libipgo.a \
/usr/bin/icpc-15.0-base/compiler/lib/libdecimal.a \
/usr/bin/icpc-15.0-base/compiler/lib/libirc.a
Usage: libtool -static [-] file [...] [-filelist listfile[,dirname]] [-arch_only arch]
Usage: libtool -dynamic [-] file [...] [-filelist listfile[,dirname]] [-arch_only arch] [-o output] [-install_name name] [-compatibility_version #] [-current_version #] [-seg1addr 0x#] [-segs_read_only_addr 0x#] [-segs_read_write_addr 0x#] [-seg_addr_table <filename>] [-seg_addr_table_filename <file_system_path>] [-all_load]
Indeed, there are two commands "syslibroot" in that case. More strange, the commands are involving two different MacOSX SDK versions... this is completely unexpected and not wanted.
* Build with a MacMini with Mac OS X 10.8.5 with installed ICC14 and ICC15 (Success)
libtool \
-static \
-arch_only \
x86_64 \
-o \
-L/usr/lib \
-syslibroot \
[The *.o files]
This case, everything is normal. Same XCode Project, same ICC version.
Has someone an idea about what could be the origin of this issue?
Thanks in advance!
JbR
It's not clear to me what's causing this, but here's a workaround that got me past this linker problem. Remove and reinstall the Xcode Command Line Tools by:
1. Delete directory /Library/Developer/CommandLineTools
2. Reinstall by running `xcode-select --install` from Terminal
That's it... hope that helps.
Hi Zach,
Indeed, after reinstalling the command line tool, the linking issue seems to not appears any more.
Thanks again for your suggestion.
