Intel® C++ Compiler
XE 2013 Update 3 breaks #import statements in x64 builds
MHlav
No longer generates tlh/tli files.  Works in x86 builds.
Always taking a step back with each step forward in the updates.
JenniferJ
From a command line, it works.
D:\Jennifer\Issues>icl /c dllissue.cpp
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.1.1.171 Build 20130313
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
dllissue.cpp
47802.cpp
47802.cpp
D:\Jennifer\Issues>type dllissue.cpp
#import "c:\program files (x86)\common files\system\ado\msado15.dll" no_namespace raw_interfaces_only
#import <cdosys.dll> no_namespace raw_interfaces_only
#include "cdosysstr.h"
#include "cdosyserr.h"
int main(int argc, char* argv[]) {
CoInitialize(NULL);
IMessage* pMsg = NULL;
HRESULT hr = CoCreateInstance( __uuidof(Message),NULL,CLSCTX_INPROC_SERVER,__uuidof(IMessage),(void**) &pMsg);
CoUninitialize();
return 0;
D:\Jennifer\Issues>dir *.tlh
Volume in drive D has no label.
Volume Serial Number is 927C-E946
Directory of D:\Jennifer\Issues
06/05/2012 11:02 PM 39,680 cdosys.tlh
06/05/2012 10:05 PM 104,014 msado15.tlh
2 File(s) 143,694 bytes
0 Dir(s) 201,670,336,512 bytes free
D:\Jennifer\Issues>
are you using VS2010 to build?
Jennifer
MHlav
VS2012.  I created a support case on the premier site.
JenniferJ
Thank you Michael. We will investigate it.
Jennifer
Marián__VooDooMan__M
New Contributor II
I'm experiencing the same issue. For now, my workaround is after "clean solution" to restore *.tlh and *.tli from backup, or adjust the code to not use "#import", but "#include" header file for my COM object. I'm waiting impatiently for next release.
MHlav
VooDooMan, I'm about to do that as well. It's just a pain to do as we have many projects that are affected.
SergeyKostrov
Valued Contributor II
Please consider the following workaround: - Generate tlh and tli files ( it is assumed that COM interfaces are in stable state, that is already implemented / I know that in some cases it is hard to be assumed ) - Comment #import directive(s) which created those tlh and tli files - Use tlh and tli files with #include directive Note: I use that workaround for many years with MapPoint COM interfaces.
JenniferJ
I duplicated this issue inside VS2012 IDE x64 config.
The only work-around I can see is the one from Sergey. I used to do that as well. It saves compilation time as well if you have lots of "#import".
But if I found any other work-around without the need of changing your code, I'll let you know.
Jennifer
JenniferJ
MHlav
SergeyKostrov
>>...4.Update "/Qlocation,link,"$(VCInstallDir)\bin\x86_amd64"" to "/Qlocation,link,"$(VCInstallDir)\bin\amd64"" Thank you and it is a very simple solution! By the way, folder ..\bin\x86_amd64 has 32-bit versions of tools and folder ..\bin\amd64 has 64-bit versions of tools.
JenniferJ
Update to this issue.
It is fixed in the Intel C++ Composer XE for Windows 2013 update 5 that is downloadable from Intel Registration Center.
Jennifer
