Hi, I installed Intel C++ Compiler (and GDB, nothing more) using Parallel Studio XE 2017 Update 1 on a macOS 10.12.2 with Xcode 8.2.
When asked about environment, I selected the option "Both command line and Xcode integration environment".
The installation completed successfully, but when I go to the target's compiler option in Xcode, there's no intel compiler (only default Apple llvm). If I manually enter the /opt/intel/bin/icc it accept, but it mark as "Unsupported compiler" and compilation fails with error: Unable to determine concrete GCC compiler for file [...]/main.cpp
Integration with Xcode 8.2 is not currently available. Support is targeted in our PSXE 2017 Update 2 release next month. You will need to down-version your Xcode to either 8.0 or 8.1 in the meantime.
The same issue was reported with Fortran: https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/707171
Thank you, Kevin. I'll patiently wait for the update.
I down-verisoned to 8.1 to be able to use Intel Fortran 2017 in Xcode. Still, I cannot choose Intel Fortran as Custom script in the "Using" menu.
I reinstalled everything and even did the trick of creating a symbolic link to 8.1 in case the default was 8.0. The Developer folder is not in /Library/Application\ Support/ as stated in the help, but in /Library/. Not sure if that could be a problem.
Anything I am missing?
Thanks!
