Intel® C++ Compiler
7956 Discussions
Xcode does not find openmp libraries
Doron_G_
Hi
Hi I install the compiler and it runs on command line. However, in Xcode it gives an error when I try to use mkl libraries or openmp libraries writing dyld... not found while executing. Please help.
TimP
This looks like a question for the forum corresponding to your compiler (C++ or Fortran?) if you don't find out the answer by reading the docs.
https://software.intel.com/en-us/inde-getting-started-compiler-on-osx
Andrey_C_Intel1
I am moving the post to C/C++ compiler forum, as it does not relate to the open source runtime.
- Andrey
Olga_M_Intel
Hi Doron,
You didn't mention the compiler version and OS X version.
Probably, you encountered the known problem described here - https://software.intel.com/en-us/articles/os-x-1011-not-supported-by-intel-parallel-studio-xe-2015.
