Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
about -funsigned-bitfields
chenghuiming_bjgmail
the document said that -funsigned-bitfieldsDetermines whether the default bitfield type is changed tounsigned. but what is default bitfield type?
thanks in advance.
Om_S_Intel
By default it is treated as signed int but this may be changed by the -funsigned-bitfields option.
You may learn more on it by following http://gcc.gnu.org/onlinedocs/gcc/Structures-unions-enumerations-and-bit_002dfields-implementation.h...
Feilong_H_Intel
Hi there,
The default bitfield type signed. Gcc manual gives more details below.
-fsigned-bitfields
-fno-signed-bitfields
-fno-unsigned-bitfields
These options control whether a bit-field is signed or unsigned, when the declaration does not use either signed or unsigned. By default, such a bit-field is signed, because this is consistent: the basic integer types such as int are signed types.
Feilong
Thank all.
I got it.
a.c:
struct node
int a:2; //no unsigned or signed before int
if compiled by icc -funsigned-bitfieds a.c , field a is unsigned int .
if compiled by icc a.c, field a is signed int.
