the document said that -funsigned-bitfieldsDetermines whether the default bitfield type is changed tounsigned. but what is default bitfield type?
thanks in advance.
By default it is treated as signed int but this may be changed by the -funsigned-bitfields option.
You may learn more on it by following http://gcc.gnu.org/onlinedocs/gcc/Structures-unions-enumerations-and-bit_002dfields-implementation.html
Hi there,
The default bitfield type signed. Gcc manual gives more details below.
-fsigned-bitfields
-fno-signed-bitfields
-fno-unsigned-bitfields
These options control whether a bit-field is signed or unsigned, when the declaration does not use either signed or unsigned. By default, such a bit-field is signed, because this is consistent: the basic integer types such as int are signed types.
Feilong
Thank all.
I got it.
a.c:
struct node
int a:2; //no unsigned or signed before int
if compiled by icc -funsigned-bitfieds a.c , field a is unsigned int .
if compiled by icc a.c, field a is signed int.
