Intel® C++ Compiler
accessing Intel C++
Reza_Ahmadian
Dear All,
I used to only have Intel Fortran Compiler on my machine. I bought Intel parallel Studio after Steve () pointed out that I need to update my compiler to resolve the issue which I had mentioned in one of my previous post. I require to use C++ and believe Intel parallel Studio include C++ compiler as well as Fortran. I have installed the compiler initially using the update option in the setup and oncei removed Intel compiler and reinstalled parallel Studio again. I have MVS 2005 and 2008 standard Edition and 2010 Sell edition. Unfortunately, I can only access Intel Visual Fortran Projects and cannot access Intel C++ projects in MVS environment. Could you please help me what I am missing here?
Many thanks,
Reza
JenniferJ
You're using the VS2010 Shell. The Intel C++ Compiler does not integrate into it, this is a limitation.
The Intel C++ Compiler can only integrate into VS2010 standard or above.
But you can use the Intel C++ within your VS2005 std and 2008 std.
Jennifer
