Intel® C++ Compiler
7838 Discussions
addcarry intrinsics generates wrong assembly and constexpr requires the variable to be initialized
cqwrteur
Please fix the bug.
https://godbolt.org/z/GPfEaP
RahulV_intel
Thanks for reporting the bugs. I have forwarded your issues to the concerned team for a fix.
Rahul
Viet_H_Intel
I copied the test case from godbolt.org, it compiled successfully with IPSXE2020.
If it is a runtime problem with Intel compiler, can you please provide us a test case?
$ icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.2.275 Build 20200623
$ icpc t.cpp -std=c++20 -Ofast -march=native -c
$ cat t.cpp
#include<cstdint>
#include<array>
#if defined(_MSC_VER)
#include<intrin.h>
#elif defined(__x86_64__) || defined(__i386__)
#include<immintrin.h>
#endif
using field_number = std::conditional_t<sizeof(std::size_t)>=8,std::array<std::uint64_t,4>,std::array<std::uint32_t,8>>;
namespace intrinsics
template<typename T>
inline constexpr bool add_carry(bool carry,T a,T b,T& out) noexcept
#if defined(_MSC_VER) || defined(__x86_64__) || defined(__i386__)
#if __cpp_lib_is_constant_evaluated >= 201811L
    if(std::is_constant_evaluated())
        return (out=a+b+carry)<a;
    else
#endif
    if constexpr(sizeof(T)==8)
      return _addcarry_u64(carry,a,b,
#if !defined(__INTEL_COMPILER ) &&(defined(__GNUC__) || defined(__clang__))
      reinterpret_cast<unsigned long long*>(std::addressof(out)));
#else
      std::addressof(out));
#endif
    else
      return _addcarry_u32(carry,a,b,std::addressof(out));
#else
#endif
inline constexpr
field_number add_reduce(field_number const& x,field_number const& y) noexcept
    using namespace intrinsics;
    field_number f
#ifdef __INTEL_COMPILER
#endif
    if constexpr(sizeof(std::size_t)>=8)
 * GCC addcarry bug
 * https://gcc.gnu.org/bugzilla/show_bug.cgi?id=97387
        bool carry{add_carry(false,x[0],y[0],f[0])};
        carry=add_carry(carry,x[1],y[1],f[1]);
        carry=add_carry(carry,x[2],y[2],f[2]);
        add_carry(carry,x[3],y[3],f[3]);
    else
        carry=add_carry(carry,x[3],y[3],f[3]);
        carry=add_carry(carry,x[4],y[4],f[4]);
        carry=add_carry(carry,x[5],y[5],f[5]);
        carry=add_carry(carry,x[6],y[6],f[6]);
        add_carry(carry,x[7],y[7],f[7]);
    return f;
field_number add_reduce2(field_number const& x,field_number const& y) noexcept
    field_number f
#endif
  bool carry{_addcarry_u64(false,x[0],y[0],f.data()+0)};
  carry=_addcarry_u64(carry,x[1],y[1],f.data()+1);
  carry=_addcarry_u64(carry,x[2],y[2],f.data()+2);
  _addcarry_u64(carry,x[3],y[3],f.data()+3);
  return f;
#endif
Viet_H_Intel
This smaller test case (constructed on your test case) compiled fine with either icpc (19.1.2) or g++ (8.1.0)
$ icpc t.cpp -std=c++2a -c
$g++ t.cpp -std=c++2a -c
$cat t.cpp
#include<cstdint>
#include<array>
inline constexpr
    field_number f
#elif defined __GNUC__
#endif
  return f;
Viet_H_Intel
Let us know if this is still an issue. Otherwise, we will close it.
Viet_H_Intel
We will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
