Intel® C++ Compiler
allocate vars and functions sequentially in .EXE
roberto_g_2
I would like to instruct the compiler and the linker on how to allocate the following code (I am using Visual Studio and Intel C++ compiler for Windows)
  large chunk of code before
static uint64_t a;
static uint64_t b;
static uint64_t c;
static uint64_t d;
static void CALLBACK foo( args ){
  /* short code using a, b, c, d */
  large chunk of code after
Specifically, I would like to instruct the compiler and the linker so that the .EXE file would allocate a, b, c, d, foo() contiguously in this order to maximize cache benefit.
The following mods seem to achieve the goal, but the external driver that invokes foo() does not like the fact that foo() is inside a segment, and thus crashes. Maybe I did not use the pragmas correctly.
#pragma code_seg(push, stack1, ".my_text")
__declspec(allocate(".my_text")) static uint64_t a;
__declspec(allocate(".my_text")) static uint64_t b;
__declspec(allocate(".my_text")) static uint64_t c;
__declspec(allocate(".my_text")) static uint64_t d;
__declspec(code_seg(".my_text")) static void CALLBACK foo( args ){
  /* do something using a, b, c, d */
#pragma code_seg(pop, stack1)
On the other hand, moving foo() outsize the segment works, but I have no guarantee that foo() is allocated soon after a, b, c, d in the .EXE
Any help is appreciated, thanks.
-Roberto
RahulV_intel
I had assumed that the issue was with code_seg pragma. So, I suggested you to try out with section pragma.
Try the below code snippet (I've allocated section for lambda function foo. It seems to work now) and let us know.
#include <iostream>
#pragma section(".my_section",read,write)
__declspec(allocate(".my_section")) static uint64_t a;
__declspec(allocate(".my_section")) static uint64_t b;
__declspec(allocate(".my_section")) static uint64_t c;
__declspec(allocate(".my_section")) static uint64_t d;
__declspec(allocate(".my_section")) static auto foo = [=](int x) -> void {
    std::cout << "Hello " << x <<"\n";
    std::cout << &a << " " << &b << " " << &c << " " << &d << "\n";
int main() {
    std::cout << "Address of foo: " << &foo << "\n";
    foo(5); //prints Hello and addresses
    return 0;
If you wish to get the values by reference for lambda function foo, change the capture clause from [=] to [&].
Specify the args of your choice in (int x).
Let us know if it works for you.
Rahul
RahulV_intel
Hi Roberto,
One way to do it is to define your static data variables and functions inside the #pragma section.
As per the documentation, code_seg pragma specifies "the text section (segment) where functions are stored in the object (.obj) file."
Kindly refer to the attached code snippet below:
__declspec(code_seg(".my_section")) static void CALLBACK foo(args) {
Let us know if it helps.
Rahul
roberto_g_2
Thank you Rahul, I will try. Do you think the effect could be different from my second snippet of code? I will let you know asap.
Edit: the external driver crashes, unless I wrap foo into a lambda function, which moves its code outside the section. I suspect that this driver does not like callbacks to be placed in segments or so. Thanks anyway :)
-Roberto
Vaidya, Rahul (Intel) wrote:
Hi Roberto,
Rahul
RahulV_intel
#include <iostream>
int main() {
    return 0;
Rahul
roberto_g_2
Rahul, it works! However... I apologize as I did not explain myself well. Variable foo is consecutively allocated as you say but I wanted foo's body as well or very closely. I modified your code with Windows' intrinsic _ReturnAddress() to print an address inside foo's body and it is quite distant from &foo.
#include <iostream>
#include <intrin.h>
#pragma intrinsic(_ReturnAddress)
    auto thisAddress = _ReturnAddress();
    std::cout << "... foo's body: " << thisAddress << "\n";
    std::cout << "Hello " << x << "\n";
int main() {
    return 0;
jimdempseyatthecove
Potential issue is that newer operating systems, in efforts to thwart viruses, use "execute only" segments for code (.text). In your earlier attempts the crash might have been resolved by adding "execute" to the section attributes. (#pragma section(".my_section",read,write,execute)
Jim Dempsey
roberto_g_2
I see this point, it makes sense if it really helps... thank you
-Roberto
RahulV_intel
That's a good point made by Jim. Adding "execute" attribute to the section helps(in the earlier code snippet).
--Rahul
roberto_g_2
Actually the address offset does not change, but it could make a difference at runtime in terms of cache performance. Thank you.
-R
--Rahul
RahulV_intel
Yes, certainly. Let us know if we can close the thread.
--Rahul
roberto_g_2
Sure, we can close the thread, thank you all!
-Roberto
RahulV_intel
You're welcome, Roberto.
Thanks for the confirmation.
