How do you create assembler modules in Intel C projects. Is the use of MS MASM required?
You may refer to this article on Inline Assembly:
http://www.intel.com/software/products/compilers/docs/clin/main_cls/intref_cls/common/intref_data_align_ma_ia_linux_ia.htm
Thank you.
No, the MS asm compiler is not required. icl can understand the asm.
Jennifer
Jennifer
