Intel® C++ Compiler
7956 Discussions
assertion failed: reconcile_routine_types: shared param types unexpected (shared/cfe/edgcpfe/decls.c, line 5524)
Aleksandr_M_
Hello!
Here is minimal working example, where combination of typedefed templated method type with static keyword results into compilation failure:
template<typename T>
using func_t = void (T x);
class MyClass
public:
    static func_t<T> method;
void MyClass::method(T x)
Namely, I am getting following error:
internal error: assertion failed: reconcile_routine_types: shared param types unexpected (shared/cfe/edgcpfe/decls.c, line 5524)"
If I simply substitute templated typedef, compilation works fine. Presented example compiles with other compilers (gnu) but fails with Intel 2015, 2016 2017 and 2018 compilers with -std=c++11 flag.
Viet_H_Intel
Thanks for report this issue. I've filed a bug internally (CMPLRIL0-31134) to address this problem.
