Intel® C++ Compiler
__attribute__(constructor) alternative
Jose_M_Monsalve_Diaz
I wrote a program that runs on Clang and GCC which relies on a function being called before the main. For this I use the __attribute__(compiler) support that is available in the other two compilers.
Is there an intel compiler alternative to this?
RahulV_intel
ICC allows __attribute__() support for user defined functions.
For instance, refer to the below code that allows you to call a function(with __attribute__ support) before main().
#include<iostream>
//Function before main
void beforeMain(void) __attribute__((constructor));
// implementation of beforeMain
void beforeMain(void) {
        std::cout << "Hello before main()\n";
int main (void) {
        std::cout << "hello\n";
    return 0;
/* Steps to compile/run
icpc filename.cpp
./a.out */
Let us know if you were successful in implementing "__attribute__" in your code whilst using icc/icpc.
--Rahul
Rahul, Thanks for your answer. I see, I actually tried it on a single source and it worked.
I could not find it documented and my code uses it and it does not seem to execute at the beginning of the program. I am trying to find a simpler reproducible of the code I have. I will report back.
Ok, I've found the problem.
The issue is with this code:
#include <iostream>
#include <stdio.h>
class ACLASS {
    public:
      static void execute_static_method() __attribute__ ((constructor)) {
        printf("execute_static_method()\n");
int main () {
  std::cout << "main" << std::endl;
  return  0;
The real issue seems to be a warning that is not raised if you are using static methods, which is the following:
warning #470: qualified name is not allowed in member declaration
If you remove the class definition, the warning is displayed.
#include <iostream>
#include <stdio.h>
// This raise the warning
void execute_fnc() __attribute__ ((constructor)) {
  printf("execute_fnc()\n");
class ACLASS {
  public:
    // This does not raise it
int main () {
  return  0;
If you separate the definition and declaration that shows the warning, it does not display the warning at all, it executes the function, but it does not execute the static method.
#include <iostream>
#include <stdio.h>
void execute_fnc() __attribute__ ((constructor));
void execute_fnc(){
class ACLASS {
  public:
    static void execute_static_method() __attribute__ ((constructor)); {
int main () {
  return  0;
The execution output is as follows
> ./main
execute_fnc()
main
But if you split the definition and declaration of the static method it does work
#include <iostream>
#include <stdio.h>
void execute_fnc(){
class ACLASS {
  public:
void ACLASS::execute_static_method() {
int main () {
  std::cout << "Here" << std::endl;
  return  0;
Now I just need to figure out how to do this with my code.
RahulV_intel
Great observation. Let us know if we can close this thread.
--Rahul
Yes, I think there is an issue ticket to be open here, but as far as this thread goes that is it.
Thanks for your quick response.
RahulV_intel
Thanks for the confirmation. We will go ahead and close this thread. Feel free to reach out to us, in case of further queries.
--Rahul
