I'm testing the new boost DLL library http://www.boost.org/doc/libs/1_61_0/doc/html/boost_dll.html
with Composer XE C++ 2016 under Visual Studio 2015 U2.
By the second example http://www.boost.org/doc/libs/1_61_0/doc/html/boost_dll/tutorial.html#boost_dll.tutorial.factory_met...
I become compile errors:
1> my_plugin_aggregator.cpp
1>my_plugin_aggregator.cpp(43): error #77: this declaration has no storage class or type specifier
1> BOOST_DLL_ALIAS(
1> ^
1>
1>my_plugin_aggregator.cpp(43): error : identifier "section" is undefined
1> BOOST_DLL_ALIAS(
1> ^
1>
1>my_plugin_aggregator.cpp(43): error : expected a ";"
1> BOOST_DLL_ALIAS(
1> ^
The problem is in dll/alias.hpp:
... #if !BOOST_OS_MACOS && !BOOST_OS_IOS /*! * \brief Macro that puts symbol to a specific section. On MacOS all the sections are put into "__DATA" segment. * \param SectionName Name of the section. Must be a valid C identifier without quotes not longer than 8 bytes. * \param Permissions Can be "read" or "write" (without quotes!). */ #define BOOST_DLL_SECTION(SectionName, Permissions) \ BOOST_STATIC_ASSERT_MSG( \ sizeof(#SectionName) < 10, \ "Some platforms require section names to be at most 8 bytest" \ ); \ __attribute__ ((section (#SectionName))) \ /**/ #else // #if !BOOST_OS_MACOS && !BOOST_OS_IOS #define BOOST_DLL_SECTION(SectionName, Permissions) \ BOOST_STATIC_ASSERT_MSG( \ sizeof(#SectionName) < 10, \ "Some platforms require section names to be at most 8 bytest" \ ); \ __attribute__ ((section ( "__DATA," #SectionName))) \ /**/ #endif // #if #if !BOOST_OS_MACOS && !BOOST_OS_IOS
Somehow the line with __attribute__ ((section is not valid for Intel C++ compiler. Microsoft VC++ 2015 compiler can easily compile this example. Is there an option or workaround to enable this __attribute__ ((section by Intel C++?
Greetings
Przemek
Hi, Przemek
Have you tried C++ Composer Edtion 2016 Update 3?
We have similar compatibility issue with Visual Studio 2015 U2(released after 2016 Update 2) and get fixed in 2016 Update 3.
See: https://software.intel.com/en-us/forums/intel-c-compiler/topic/623368
Hi Yolanda,
I know that isuue, and I have Intel 2016 Update 3.
After some research I figured out, that this __attribute__ section is a gcc compiler feature.
The problem is in this alias.hpp header from boost dll library. It detect wrong compiler if I compile from VC++ with Intel C++ and it try to compile code for gcc. VC++ only works well. I will ask on boost forum.
Przemek
When compiled with Visual Studio compiler, it enables the following BOOST_DLL_ALIAS definition in alias.hpp:
#if BOOST_COMP_MSVC #define BOOST_DLL_SELECTANY __declspec(selectany) #define BOOST_DLL_SECTION(SectionName, Permissions) \ BOOST_STATIC_ASSERT_MSG( \ sizeof(#SectionName) < 10, \ "Some platforms require section names to be at most 8 bytest" \ ); \ __pragma(section(#SectionName, Permissions)) __declspec(allocate(#SectionName)) \ /**/ #else // #if BOOST_COMP_MSVC
Thus Microsoft compiler never has to deal with __attribute__((section)) but rather deals with #pragma(section). As Yolanda works with Boost folks on this, you can try the following work around in alias.hpp:
#if BOOST_COMP_MSVC || (__INTEL_COMPILER && _WIN32) #define BOOST_DLL_SELECTANY __declspec(selectany) #define BOOST_DLL_SECTION(SectionName, Permissions) \ BOOST_STATIC_ASSERT_MSG( \ sizeof(#SectionName) < 10, \ "Some platforms require section names to be at most 8 bytest" \ ); \ __pragma(section(#SectionName, Permissions)) __declspec(allocate(#SectionName)) \ /**/ #else // #if BOOST_COMP_MSVC
Thanks and Regards
Anoop
I have misinterpret the compiler error with this __attribute__((section)).
Clearly VC++ use #pragma(section), but working with Intel C++ is the maro
BOOST_COMP_MSVC
not set. I have used a similar workaround in alias.hpp
Thanks and Regards
Przemek
Hello again,
this problem still exists in boost, so I have to patch every new version of the DLL library.
I have created an issue in boost trac: https://svn.boost.org/trac10/ticket/13192
Could you please contact boost team, so they can fix this in next release.
Thanks and Regards
Przemek
