I'm experimenting with automatic vectorization support in ICC XE 12 (beta build 20100512 for windows, C++) and am getting some puzzling assembly for output. Essentially, instead of using min/max SSE functions, the assembly goes through a long convoluted series of XORs etc.
I want to loop over three arrays to compute a min/max for the 4th:
for each i:
res = min(max(first, second), third));
Ideally, this will use the min and max SSE functions. Furthermore, I'm trying to guarentee alignment of the arrays and to avoid checking for leftovers. The goal is to write this with pragmas etc. outside of the loop body (no assembly, few intrinsics) and not touch the loop body itself. E.g., going a little overboard:
void computeLvlSIMD(Level *lvl, Inherited &inh) { unsigned int len4 = lvl->lengthBy4; unsigned int len = 4 * len4; //no carry-over hintable? int *inhW = inh.w; int *w = lvl->w; int *minw = lvl->minw; int *prefw = lvl->prefw; __assume_aligned(inhW, 16); __assume_aligned(w, 16); __assume_aligned(minw, 16); __assume_aligned(prefw, 16); #pragma ivdep #pragma vector aligned #pragma vector always for (unsigned int i = 0; i < len; i ++) { int max = inhW; //note that the loop body is 'normal' code if (minw > max) max = minw; int min = max; if (prefw < min) min = prefw; w = min; } }
However, the generated assembly does a long series of pxor's etc. instead of movdqa/movdqa/movdqa/max/min/movdqa:
; -- Machine type EFI2 ; mark_description "Intel C++ Compiler XE for applications running on Intel 64, Version 12.0.0.030 Beta Build 20100512"; ; mark_description "-O3 -Qstd=c99 -QaxSSE4.2 -Qvec-report:3 -S"; ... .B1.4:: ; Preds .B1.4 .B1.3 $LN25: $LN26: movdqa xmm0, XMMWORD PTR [r11+rdx*4] ;8.13 $LN27: add eax, 4 ;19.3 $LN28: movdqa xmm1, XMMWORD PTR [rbx+rdx*4] ;6.13 $LN29: movdqa xmm3, xmm0 ;21.5 $LN30: pcmpgtd xmm3, xmm1 ;21.5 $LN31: pxor xmm0, xmm1 ;21.5 $LN32: pand xmm3, xmm0 ;21.5 $LN33: cmp eax, r8d ;19.3 $LN34: pxor xmm3, xmm1 ;21.5 $LN35: movdqa xmm2, XMMWORD PTR [rcx+rdx*4] ;9.14 $LN36: movdqa xmm4, xmm3 ;23.5 $LN37: pcmpgtd xmm4, xmm2 ;23.5 $LN38: pxor xmm2, xmm3 ;23.5 $LN39: pand xmm4, xmm2 ;23.5 $LN40: pxor xmm4, xmm3 ;23.5 $LN41: movdqa XMMWORD PTR [r10+rdx*4], xmm4 ;7.10 $LN42: mov edx, eax ;19.3 $LN43: jb .B1.4 ; Prob 82% ;19.3Any tips would be appreciated!
__m128i inhwQ, minwQ, prefwQ; //i32 __m128i min, max; for (unsigned int i = 0; i < len4; i += 4) { inhwQ = _mm_load_si128(inhw + i); minwQ = _mm_load_si128(minw + i); prefwQ = _mm_load_si128(prefw + i); min = _mm_min_epi32(inhwQ, minwQ); max = _mm_max_epi32(prefwQ, min); _mm_store_si128(w + i, max); }
and the expected assembly like
$LN16: movdqa xmm0, XMMWORD PTR [rdx+r10] ;22.25 $LN17: pminsd xmm0, XMMWORD PTR [rax+r10] ;25.8 $LN18: movdqa xmm1, XMMWORD PTR [r11+r10] ;24.26 $LN19: pmaxsd xmm1, xmm0 ;26.8 $LN20: movdqa XMMWORD PTR [r8+r10], xmm1 ;27.18 $LN21:
- L
You can either provide the test case as a private attachment or submit via Intel Premier Support at https://premier.intel.com/
--mark
#includeCompiled withvoid strange (unsigned int len) { unsigned int len4 = (len + 3) / 4; unsigned int len1 = 4 * len4; int *a = (int *) _aligned_malloc( sizeof(int) * len1, 16);
int *b = (int *) _aligned_malloc( sizeof(int) * len1, 16);
int *c = (int *) _aligned_malloc( sizeof(int) * len1, 16);
int *res = (int *) _aligned_malloc( sizeof(int) * len1, 16);
__assume_aligned(a, 16); __assume_aligned(b, 16); __assume_aligned(c, 16); __assume_aligned(res, 16); #pragma ivdep #pragma vector aligned #pragma vector always for (unsigned int i = 0; i < len1; i ++) { int tmp = a; if (b > tmp) tmp = b; if (c < tmp) tmp = c; res = tmp; } }
"C:\Program Files (x86)\Intel\CompilerPro-12.0\bin\intel64\icl" /O3 /c /Qstd=c99 /QaxSSE4.2 /Qvec-report:1 IsolatedIntrinsics.cpp /SThanks!
--mark
movdqa xmm0, XMMWORD PTR [rdi+rcx*4] ;7.117
add edx, 4 ;16.3
pmaxsd xmm0, XMMWORD PTR [r12+rcx*4] ;18.2
cmp edx, r8d ;16.3
pminsd xmm0, XMMWORD PTR [rsi+rcx*4] ;19.2
movdqa XMMWORD PTR [rax+rcx*4], xmm0 ;7.239
mov ecx, edx ;16.3
jb .B1.8 ; Prob 82% ;16.3
I will look further and get back to you.
--mark
Yes; using <4 * len" does help quite a lot !
I filed a report to resolve the case where using /QaxSSE4.2 does not generate the expected min/max instructions and will let you know the issue is resolved.
--mark
