[cpp]
void foo(int a) {
while(a);
int main() {
foo(1);
}[/cpp]
Compiler removes empty loop and there is no endless loop that i expect. MSVC and GCC works correctly.
Windows, ICC 13.1.
With Intel C++ compiler this is a well know issue but it is Not a problem. What optimization options did you use, /O1, /O2 or /O3?
With any level of optimization.
>>...Compiler removes empty loop and there is no endless loop that i expect...
Do you need to use a similar processing in a real application?
Adding "#pragma intel optimization_level 0" before the function "foo()" will keep the loop.
Or introduce a volatile variable like below:
//#pragma intel optimization_level 0
void foo(int a) {
volatile int b=a;
while(a)
Okay, i forgot about volatile, thanks.
