Intel® C++ Compiler
7956 Discussions
bad runtime value passed for constexpr value in c++17
vindriolo
In certain cases, functions that take in const ref values are getting invalid/undefined values at runtime when passing in static constexpr members with -std=c++17.  But the same example fails to link with -std=c++14.
OS: CentOS Linux release 7.8.2003 (Core)
GCC: g++ (GCC) 8.3.1 20190311 (Red Hat 8.3.1-3)
Compiler versions tested:
    icpc (ICC) 19.0.1.144 20181018
    icpc (ICC) 19.0.4.227 20190416
    icpc (ICC) 19.0.4.243 20190416
    icpc (ICC) 19.1.2.254 20200623
Command line:
$ icpc -std=c++17 ./constexpr_test.cpp && ./a.out
a.out: ./constexpr_test.cpp:30: void SomeClass<A>::check(const unsigned int &) [with A = int]: Assertion `key != 0' failed.
Aborted (core dumped)
$ icpc -std=c++14 ./constexpr_test.cpp && ./a.out
/tmp/icpcub4xzI.o: In function `main':
constexpr_test.cpp:(.text+0x2c): undefined reference to `SomeClass<int>::SPECIFIC_KEY'
below is a code example:
#include <cassert>
#include <cstdint>
#include <cstdio>
#include <limits>
// works if SomeClass is not a template
template <typename A>
struct SomeClass
  static constexpr uint32_t SPECIFIC_KEY = std::numeric_limits<uint32_t>::max();
  // Uncommenting this works around the issue
  // static_assert(SPECIFIC_KEY != 0, "SPECIFIC_KEY is 0!");
  SomeClass()
    check(SPECIFIC_KEY);
    // Uses safely w/o workarounds, but doesn't fix
    //check(uint32_t(SPECIFIC_KEY));
    // Uncommenting this works around the issue, presumably because it requires a const reference
    // printf("specific key: %d\n", SPECIFIC_KEY);
private:
  void check(const uint32_t& key)
    assert(key != 0);
int main(int argc, char** argv)
  SomeClass<int> user;
  return 0;
RahulV_intel
The issue is reproducible with icpc (ICC) 2021.1 Beta 20200827. I have informed this issue to the concerned team. Thanks for reporting this.
Rahul
Viet_H_Intel
I have reported this issue to our Developer.
There is icpx in 19.1.2.254. Can you use it for the time being?
$ icpc -V
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.2.254 Build 20200623
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
$ icpc t.cpp -std=c++17 && ./a.out
a.out: t.cpp:18: void SomeClass<A>::check(const unsigned int &) [with A = int]: Assertion `key != 0' failed.
$ icpx t.cpp -std=c++17 && ./a.out
Seems like this feature isn't supported in C++14, as both icpc and g++ ( tested on 8.1.0) gave error.
$ icpc t.cpp -std=c++14
/tmp/icpcVyN1zZ.o: In function `main':
t.cpp:(.text+0x28): undefined reference to `SomeClass<int>::SPECIFIC_KEY'
$ g++ t.cpp -std=c++14
/tmp/cc6Wwwqg.o: In function `SomeClass<int>::SomeClass()':
t.cpp:(.text._ZN9SomeClassIiEC2Ev[_ZN9SomeClassIiEC5Ev]+0x11): undefined reference to `SomeClass<int>::SPECIFIC_KEY'
collect2: error: ld returned 1 exit status
vindriolo
When using icpx, the assert does not hit with -std=c++17.  What is this binary, an experimental build of the compiler?
Viet_H_Intel
This compiler is based on LLVM technology.
RahulV_intel
Hi @vindriolo,
As pointed out by @Viet_H_Intel, the source code works fine with the ICPX compiler. Let us know if you face any issues.
Rahul
PrasanthD_intel
Hi Vince,
We are closing this thread as we haven't heard back from you, assuming your issue has been resolved. We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Prasanth
