I try to compile simple example from http://www.boost.org/doc/libs/1_61_0/libs/multi_array/doc/user.html#sec_resize
#include "stdafx.h" #include <boost\multi_array.hpp> int main() { typedef boost::multi_array<int, 3> array_type; array_type::extent_gen extents; array_type A(extents[3][3][3]); A[0][0][0] = 4; A[2][2][2] = 5; A.resize(extents[2][3][4]); return 0; }
and get following error with Intel C++ 2016 Update 3 under VC++ 2015 Update 2:
1>------ Build started: Project: multiarray, Configuration: Debug Win32 ------ 1> multiarray.cpp 1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xutility(2313): error : no instance of overloaded function "std::_Copy_no_deprecate1" matches the argument list 1> argument types are: (boost::detail::multi_array::array_iterator<int, const int *, boost::mpl::size_t<3U>, boost::detail::multi_array::const_sub_array<int, 2U, const int *>, boost::iterators::random_access_traversal_tag>, boost::detail::multi_array::array_iterator<int, const int *, boost::mpl::size_t<3U>, boost::detail::multi_array::const_sub_array<int, 2U, const int *>, boost::iterators::random_access_traversal_tag>, boost::detail::multi_array::array_iterator<int, int *, 1> boost::mpl::size_t<3U>, boost::detail::multi_array::sub_array<int, 2U>, boost::iterators::random_access_traversal_tag>, boost::iterators::detail::iterator_category_with_traversal<std::input_iterator_tag, boost::iterators::random_access_traversal_tag>, boost::iterators::detail::iterator_category_with_traversal<std::input_iterator_tag, boost::iterators::random_access_traversal_tag>) 1> return (_Copy_no_deprecate1(_Unchecked(_First), _Unchecked(_Last), 1> ^ 1> detected during: 1> instantiation of "_OutIt std::_Copy_no_deprecate(_InIt, _InIt, _OutIt) [with _InIt=boost::detail::multi_array::array_iterator<int, const int *, boost::mpl::size_t<3U>, boost::detail::multi_array::const_sub_array<int, 2U, const int *>, boost::iterators::random_access_traversal_tag>, _OutIt=boost::detail::multi_array::array_iterator<int, int *, boost::mpl::size_t<3U>, boost::detail::multi_array::sub_array<int, 2U>, boost::iterators::random_access_traversal_tag>]" at line 2323 1> instantiation of "_OutIt std::copy(_InIt, _InIt, _OutIt) [with _InIt=boost::detail::multi_array::array_iterator<int, const int *, boost::mpl::size_t<3U>, boost::detail::multi_array::const_sub_array<int, 2U, const int *>, boost::iterators::random_access_traversal_tag>, _OutIt=boost::detail::multi_array::array_iterator<int, int *, boost::mpl::size_t<3U>, boost::detail::multi_array::sub_array<int, 2U>, boost::iterators::random_access_traversal_tag>]" at line 318 of 1> "c:\Users\oley\documents\visual studio 2015\Projects\multiarray\packages\boost.1.61.0.3\build\native\..\..\lib\native\include\boost/multi_array/view.hpp" 1> instantiation of "boost::detail::multi_array::multi_array_view<T, NumDims> &boost::detail::multi_array::multi_array_view<T, NumDims>::operator=(const boost::detail::multi_array::multi_array_view<T, NumDims> &) [with T=int, NumDims=3U]" at line 447 of "c:\Users\oley\documents\visual studio 2015\Projects\multiarray\packages\boost.1.61.0.3\build\native\..\..\lib\native\include\boost\multi_array.hpp" 1> instantiation of "boost::multi_array<T, NumDims, Allocator> &boost::multi_array<T, NumDims, Allocator>::resize(const boost::detail::multi_array::extent_gen<NumDims> &) [with T=int, NumDims=3U, Allocator=std::allocator<int>]" at line 16 of "multiarray.cpp" 1> 1> compilation aborted for multiarray.cpp (code 2) ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Without Intel C++ it works fine.
Greetings
Przemek
Thanks Przemek for reporting this problem. I will try to reproduce this issue.
Anoop
Hi, thanks for looking into this. I have also seen this error quite a few times through our codebase. I am using Intel C++ 2016 Update 3, VC++ 2015 Update 2 and Boost 1.60. I can confirm that the error doesn't occur with the Microsoft v120 and v140 compilers.
Hi Anoop,
were you able to reproduce that issue. Have you gat any clue or better workaround?
Best regards
Przemek
Hi, it does not occure anymore after installing VS Update 3.
