Intel® C++ Compiler
braced-init-list in ranged for loop is not supported (C++11)?
Andrey_K_
Hi, according C++11 specification (in my case I refer to draft n3376) the following 'for' construction is valid:
#include <iostream>
int main(void) {
    for (auto x : { 0, 1, 2 }){
        std::cout << x;
But trying to compile it with intel c++ compiler gives me error:
main.cpp(3): error : assertion failed at: "shared/cfe/edgcpfe/il.c", line 15066
I have installed the following compiler: Intel® C++ Composer XE 2013 SP1 Update 2 Integration for Microsoft* Visual Studio* 2013, Version 14.0.1290.12
Hubert_H_Intel
Andrey,
With the Intel® Composer XE 2015 Beta we have full C++11 support now. Would you like to try it out?
http://software.intel.com/en-us/articles/intel-software-development-tools-2015-beta
On Linux we have support for initializer lists with g++ 4.4. So - as Franz mentions - the Intel Composer XE 2013 SP1 compiles on openSUSE 13.2 which is g++ 4.8 based.
By the way: Which is your serial number of the Intel C++ Composer XE v14.0? You can answer via "Send Author A Message". Thanks!
Regards, Hubert.
bernaske
Hi Andrey,
i have Your sample compile under openSUSE 13.2 Linux no probems on compile and execute see output:
linux-cuda60:/system_programming/projects # icpc -m64 -std=c++11 testicc.c
linux-cuda60:/system_programming/projects # icpc -m64 -std=c++11 testicc.c -o test1
linux-cuda60:/system_programming/projects # ./test1
012linux-cuda60:/system_programming/projects #
icpc (ICC) 14.0.2 20140120
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.         this is my compiler version
regards
Franz
Hubert_H_Intel
Andrey,
Regards, Hubert.
Andrey_K_
If I understand the right way, the Intel Composer XE 2013 SP1 for windows should be based on MSVC, but MSVC12 also support initializer_list, and can compile the example above
Hubert_H_Intel
Andrey,
Yes, the MSVC12 compiles the code. The Intel compiler is based on MSVC since we do not have our own standard libraries and a linker.
Does this answer your question?
Hubert.
Andrey_K_
Yes, with the Intel® Composer XE 2015 Beta it works fine, thank you.
