Intel® C++ Compiler
bug in C++ compiler 14.0.0: nonvirtual function cannot be declared with "abstract" or "sealed" modifier
Bocci__Andrea
When:
 - a templated class inherits from one of the template arguments
 - a method overrides a (supposedly virtual) method of the base class, declarig it as "final", without declaring it "virtual" in the derived class
icpc comlains with
error: nonvirtual function cannot be declared with "abstract" or "sealed" modifier
while gcc (4.8.1) happily compiles the code.
How to reproduce:
class Base {
public:
  virtual const char * name() {
    return "Base";
template <class B>
class Derived : public B {
public:
  const char * name() final {
    return "Derived";
 Also, the error message is misleading, it should mention "override" or "final", not "abstract" or "sealed" (from C# ?).
Bocci__Andrea
And here is the actual error:
$ g++ -std=c++11 test.cpp -c -o test.o
$ icpc -std=c++11 test.cpp -c -o test.o
test.cpp(12): error: nonvirtual function cannot be declared with "abstract" or "sealed" modifier
compilation aborted for test.cpp (code 2)
Georg_Z_Intel
Hello, Thank you for reporting. I agree that this case should be allowed and the error message has to be rephrased. We'll track that as DPD200388855 and I'll inform you once implemented. The alternative is to apply the "virtual" keyword to the derived class' function as well. Best regards, Georg Zitzlsberger
Bocci__Andrea
Yes, that's what we can do in the meantime.
.Andrea
Bocci__Andrea
For the record - this is still open with
$ icpc -v
icpc version 14.0.1 (gcc version 4.8.0 compatibility)
Shahzad_Malik_MUZAFF
and it is also open in 14.0.2
and looks like it is still open in "Intel C++ Composer XE 2015 Pre-Release beta"
Georg_Z_Intel
DPD200388855 is still at engineering. Once there's some progress I'll update this thread.
Georg Zitzlsberger
Georg_Z_Intel
Intel(R) Parallel Studio XE 2015 Composer Edition contains the fix.
Georg Zitzlsberger
