testcomplex.cpp:
#include
int main()
using namespace std;
complex < double > c(1,2);
double d[2];
d[0] = c.real();
d[1] = c.imag();
return 0;
Compile it,
icc -V -O3 -tpp2 -ip testcomplex.cpp
Intel C Itanium Compiler for Itanium-based applications
Version 9.0 Build 20050430 Package ID: l_cc_p_9.0.021
Copyright (C) 1985-2005 Intel Corporation. All rights reserved.
Edison Design Group C/C++ Front End, version 3.4.1 (Apr 29 2005 17:52:57)
Copyright 1988-2004 Edison Design Group, Inc.
(0): internal error: 20000_1
compilation aborted for testcomplex.cpp (code 4)
But old ICC works fine,
/opt/intel_cc_80/bin/icc -V -O3 -tpp2 -ip testcomplex.cpp
Version 8.1 Build 20050518 Package ID: l_cc_pc_8.1.032
Edison Design Group C/C++ Front End, version 3.3 (May 19 2005 08:33:56)
Copyright 1988-2003 Edison Design Group, Inc.
GNU ld version 2.15.92.0.2 20040927
Supported emulations:
elf64_ia64
elf_i386
i386linuxh
Now add the following at the beginning,
#include < vector >
#include < iostream >
and the following before "return 0;",
vector < complex < double > > vc;
vc.resize(5);
double vd[10];
for (int i=0; i<5; i++) vc = sqrt(complex < double > (-i));
for (int i=0; i<5; i++) vd[i*2] = vc.real();
for (int i=0; i<5; i++) vd[i*2+1] = vc.imag();
for (int i=0; i<10; i++) cout << vd << " ";
cout << endl;
Then both versions refuse to work,
FATAL ERROR : Compiler Internal Error
compilation aborted for testcomplex.cpp (code 2)
icc -V -O3 -tpp2 -ip testcomplex.cpp Intel C Itanium Compiler for
Message Edited by yager@netease.com on 06-25-2005 04:59 PM
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
