When compiling the code snippet below with
icc -std=c++11 -m64 -mfpmath=sse -march=core-avx2 -Wall -Wextra -O0 -g -c test.o test.cpp
using icc (ICC) 17.0.0 20160721, I get the warning message
test.cpp(6): warning #175: subscript out of range
data[5] = x;
detected during instantiation of "T foo<T>::baz(T) [with T=int]" at line 13]
template <typename T> struct foo { T data[sizeof(T)] = {0}; T baz(int x) { if(sizeof(T) > 4) { data[5] = x; } return data; } }; int main() { foo<int> x; int a = x.baz(3); foo<double> y; int b = y.baz(5); return a + b; }
The DCE pass is correctly eliminating the conditional in baz, so it appears that the array bounds check is happening too soon here.
test.o: file format elf64-x86-64 Disassembly of section .text: 0000000000000000 <main>: 0: 55 push rbp 1: 48 89 e5 mov rbp,rsp 4: 48 83 e4 80 and rsp,0xffffffffffffff80 8: 48 81 ec 80 00 00 00 sub rsp,0x80 f: 33 f6 xor esi,esi 11: bf 03 00 00 00 mov edi,0x3 16: e8 00 00 00 00 call 1b <main+0x1b> 1b: c5 f8 ae 1c 24 vstmxcsr DWORD PTR [rsp] 20: 81 0c 24 40 80 00 00 or DWORD PTR [rsp],0x8040 27: c5 f8 ae 14 24 vldmxcsr DWORD PTR [rsp] 2c: b8 05 00 00 00 mov eax,0x5 31: c5 f8 77 vzeroupper 34: 48 89 ec mov rsp,rbp 37: 5d pop rbp 38: c3 ret
gcc organizes its compiler passes differently than icc. We do all the semantic checking before we do dead code elimination.
--Melanie
Actually Gnu doesn't give an warning even if the code is not dead (i.e. there truly is an out of bound violation), i.e.:
sptxl15-405> cat foo.cpp
struct foo {
T baz(int x) {
data[5] = x;
return data
int main() {
foo<int> x;
int a = x.baz(3);
foo<double> y;
int b = y.baz(5);
return a + b;
sptxl15-406> icpc -Warray-bounds -c foo.cpp
foo.cpp(7): warning #175: subscript out of range
data[5] = x;
detected during instantiation of "T foo<T>::baz(int) [with T=int]" at line 16
foo.cpp(16): (col. 15) remark #13384: Possible access beyond allocated symbol x.10.0.3 sized 16 bytes
sptxl15-407> g++ -Warray-bounds -c foo.cpp
sptxl15-408>
