I do not know how to explain this bug with my poor English.
Here is the section where I think the bug occured.
int lv = 0;
int SonPID0 = 183;
int GrandPID0 = 160;
if ( GrandPID0 != -1 )
patch->ptr[0][lv+1][SonPID]->son = GrandPID0;
for (int GrandPID=GrandPID0; GrandPID
if there is no bug, the code will excute
patch->ptr[0][1][183]->son = 160;
patch->ptr[0][2][160]->father = 183;
patch->ptr[0][2][161]->father = 183;
patch->ptr[0][2][162]->father = 183;
patch->ptr[0][2][163]->father = 183;
patch->ptr[0][2][164]->father = 183;
patch->ptr[0][2][165]->father = 183;
patch->ptr[0][2][166]->father = 183;
patch->ptr[0][2][167]->father = 183;
but acutully the following was done
patch->ptr[0][2][168]->father = 183;
It left"patch->ptr[0][2][160]->father" behind, but write to the wrong place "patch->ptr[0][2][160]->father"
I checked my code several times, until I used the Intel Debugger which printed the value of these variable.
So I think it may have a bug in the loop unrolling.
Is there any way by which I can upload my whole code to be analize?
But the whole program contains about ten thousand lines.
What should I do to report this bug officially?
Thank you.
I did find a work-around. Building "buffer.cpp" with -O1 works.
I'll file a bug to the compiler team to fix. But for now please use the work-around.
Thanks for reporting!
Jennifer
[cpp][/cpp][cpp]aa
I took a lot of effort to minimize the code, and now there are only tens of line in this code. The result should be 1 1 0 0 but Intel C Compiler (11.1.069) give 0 0 1 0 with the commannd line icpc Main.cpp Refine_Buffer.cpp && ./a.out OS : CentOS 5.4 with kernel 2.6.18-164.11.1.el5 ############################# GAMER.h ################################### #includeusing namespace std; struct patch_t { int corner[3]; int father; }; struct AMR_t { patch_t *ptr[2][4]; }; ########################## End of GAMER.h ################################# ############################# Main.cpp ################################### #include "GAMER.h" AMR_t *patch; int abc[3]; void Refine_Buffer(const int lv); int main() { patch = (AMR_t*) calloc( 1, sizeof(AMR_t) ); for( int i = 0; i < 2; i++ ) for( int j = 0; j < 4; j++ ) patch->ptr = (patch_t*) calloc( 1, sizeof(patch_t) ); for( int i = 0; i < 3; i++ ) abc = i; patch->ptr[0][1]->father = 1; Refine_Buffer(0); for( int i = 0; i < 4; i++ ) cout << patch->ptr[1]->father << endl; return 0; } ########################## End of Main.cpp ################################## ######################## Refine_Buffer.cpp ################################## #include "GAMER.h" extern AMR_t *patch; extern int abc[3]; void Refine_Buffer( const int lv ) { for (int s=0; s<2; s++) { for (int SonPID=abc ; SonPIDptr[lv][SonPID]->father == 1 ) { for (int GrandPID=0; GrandPID<2; GrandPID++) patch->ptr[1][GrandPID]->father = SonPID; } } } } ##################### End of Refine_Buffer.cpp ##############################[/cpp]
May somebody help me to report this bug to engineers of intel, or test the bug to see if itis really from the Compiler ?
Thanks very much.
"You are attempting to access Intel Premier Support but you do not have a user account."
Is there anythingI missed so that I didn't register the account?
Thank you for your reply.
I have only this account to visit the forum and knowledge base.
Can Non-Commercial Key get the premier support ?
Yes, you can create a Premier Support account when you sign-up for eval or NCOM. There is a check-box for creating a Premier Support account.
Thanks for cutting down the testcase. It's usually very time consuming.
Jennifer
could you let me know your compile options?
On Linux, ic 11.1.069, even I turned off unroll, it still gives me wrong result except using -O0.
Jennifer
Inthe original case, turn off the optimization option will fix the bug, and the idb gives the value of variables intended to be changed with an offset so I thought it's unroll bug at that time.
After cutting the code down, some properties changed, so the -unroll0 optionmakes no difference.
In the original case, there are a lot of trick to suppress the bugfor examplecout the loop counter or the value of variable which is changed in the loop.
I am deeply grateful that you have paid attention to this bug.
best regards,
Yu-Chih
But I will try the suggestion and try to understand it.
Thanks for the new knowledge providing.
int lv = 0;
int SonPID0 = 183;
for (int GrandPID=GrandPID0; GrandPID++GrandPID)
patch->ptr[0][lv+2][GrandPID]->father = SonPID;}
const int lv = 0;
static const unsigned intSonPID0 = 183;
static const unsigned int GrandPID0 = 160;
{patch->ptr[0][lv+1][SonPID]->son = GrandPID0;
for (unsigned int GrandPID=GrandPID0; GrandPID
Our report shows this issue in the original posting has been fixed in the latest 11.1 update 8 and 12.0 compiler update2.
Jennifer
