I'd like to report a compilation failure for this code (first part is just for C++14 support) :
//////////// NOT INTERESTING PART /////////////////////// namespace std { template <typename T, T... Is> struct integer_sequence { using value_type = T; static_assert(std::is_integral<T>::value, "std::integer_sequence can only be instantiated with an integral type" ); static inline size_t size() { return (sizeof...(Is)); } }; template <size_t... Is> using index_sequence = integer_sequence<size_t, Is...>; namespace integer_sequence_detail { template <typename T, size_t... Extra> struct repeat; template <typename T, T... Is, size_t... Extra> struct repeat<integer_sequence<T, Is...>, Extra...> { using type = integer_sequence<T, Is..., 1 * sizeof...(Is) + Is..., 2 * sizeof...(Is) + Is..., 3 * sizeof...(Is) + Is..., 4 * sizeof...(Is) + Is..., 5 * sizeof...(Is) + Is..., 6 * sizeof...(Is) + Is..., 7 * sizeof...(Is) + Is..., Extra...>; }; template <size_t N> struct parity; template <size_t N> struct make : parity<N % 8>::template pmake<N> {}; template <> struct make<0> { using type = integer_sequence<size_t>; }; template <> struct make<1> { using type = integer_sequence<size_t, 0>; }; template <> struct make<2> { using type = integer_sequence<size_t, 0, 1>; }; template <> struct make<3> { using type = integer_sequence<size_t, 0, 1, 2>; }; template <> struct make<4> { using type = integer_sequence<size_t, 0, 1, 2, 3>; }; template <> struct make<5> { using type = integer_sequence<size_t, 0, 1, 2, 3, 4>; }; template <> struct make<6> { using type = integer_sequence<size_t, 0, 1, 2, 3, 4, 5>; }; template <> struct make<7> { using type = integer_sequence<size_t, 0, 1, 2, 3, 4, 5, 6>; }; template <> struct parity<0> { template <size_t N> struct pmake : repeat<typename make<N / 8>::type> {}; }; template <> struct parity<1> { template <size_t N> struct pmake : repeat<typename make<N / 8>::type, N - 1> {}; }; template <> struct parity<2> { template <size_t N> struct pmake : repeat<typename make<N / 8>::type, N - 2, N - 1> {}; }; template <> struct parity<3> { template <size_t N> struct pmake : repeat<typename make<N / 8>::type, N - 3, N - 2, N - 1> {}; }; template <> struct parity<4> { template <size_t N> struct pmake : repeat<typename make<N / 8>::type, N - 4, N - 3, N - 2, N - 1> {}; }; template <> struct parity<5> { template <size_t N> struct pmake : repeat<typename make<N / 8>::type, N - 5, N - 4, N - 3, N - 2, N - 1> {}; }; template <> struct parity<6> { template <size_t N> struct pmake : repeat<typename make<N / 8>::type, N - 6, N - 5, N - 4, N - 3, N - 2, N - 1> {}; }; template <> struct parity<7> { template <size_t N> struct pmake : repeat<typename make<N / 8>::type, N - 7, N - 6, N - 5, N - 4, N - 3, N - 2, N - 1> {}; }; template <typename T, typename U> struct convert { template <typename> struct result; template <T ...Is> struct result<integer_sequence<T, Is...>> { using type = integer_sequence<U, Is...>; }; }; template <typename T> struct convert<T, T> { template <typename U> struct result { using type = U; }; }; template <typename T, T N> using make_integer_sequence_unchecked = typename convert<size_t, T>::template result<typename make<N>::type>::type; template <typename T, T N> struct make_integer_sequence { static_assert(std::is_integral<T>::value, "std::make_integer_sequence can only be instantiated with an integral type"); static_assert(0 <= N, "std::make_integer_sequence input shall not be negative"); using type = make_integer_sequence_unchecked<T, N>; }; } // namespace integer_sequence_detail template <typename T, T N> using make_integer_sequence = typename integer_sequence_detail::make_integer_sequence<T, N>::type; template <size_t N> using make_index_sequence = make_integer_sequence<size_t, N>; template <typename... T> using index_sequence_for = make_index_sequence<sizeof...(T)>; } // namespace std //////////// INTERESTING PART /////////////////////// template <size_t dim> struct vec { float va[dim]; explicit constexpr vec(const float& value) noexcept : vec(std::make_index_sequence<dim>(), value) {} protected: //! Expanding constructor repeating the same scalar value. template <size_t... Is> inline constexpr vec(std::index_sequence<Is...>, const float& value) noexcept : va{(void(Is), value)...} {} }; int main(void) { vec<2> a(0.0f); }
The output is :
main.cpp(301): error : no instance of constructor "vec<dim>::vec [with dim=2Ui64]" matches the argument list 1> argument types are: (std::make_index_sequence<2Ui64>, const float) 1> : vec(std::make_index_sequence<dim>(), value) {} 1> ^ 1> detected during instantiation of "vec<dim>::vec(const float &) [with dim=2Ui64]" at line 312 1> 1>main.cpp(312): error : assertion failed at: "shared/cfe/edgcpfe/exprutil.c", line 14888 1> 1> vec<2> a(0.0f);
Thanks for your answers.
Hi, since the post stayed as a draft for 2 days I tried ICC 2015 beta and the bug is fixed.
The workaround for this special case (with 14.0.2) is to replace "index_sequence<" by "integer_sequence<size_t, " line 124.
Thx for the fix in the 2015 version !!
Great, was about to test it out with 15.0 myself when I saw your response Even. Thanks for letting us know :-)
_Kittur
