Howdy All,
As far as I can tell the code below is valid C++11 syntax, and it compiles/runs fine with both gcc and clang. However, I've tried it with both icc version 12.1.5 and 13.0.0 and get the following error:
nthomas@sanpedro> icc -std=c++0x -o test test.cc
test.cc(64): error: no instance of function template "Proxy<T>::invoke2 [with T=A]" matches the argument list
argument types are: (void (A::*)(int), int)
object type is: Proxy<A>
this->invoke2(&T::foo, x); // error with icc, compiles with gcc & clang
detected during instantiation of "void Proxy<T>::foo(int) [with T=A]" at line 76
test.cc(65): error: no instance of function template "Proxy<T>::invoke3 [with T=A]" matches the argument list
this->invoke3(&T::foo, x); // error with icc, compiles with gcc & clang
Here's the code (I've also attached a file):
#include <iostream>
#include <type_traits>
template<typename T>
struct identity
typedef T type;
struct A
void foo(int x)
std::cout << "Hello World " << x << "\n";
struct invoker
T m_t;
invoker(T& t)
: m_t(t)
template<typename Class, typename ...Args>
void invoke1(void (Class::* pmf)(Args...), Args... args)
(m_t.*pmf)(args...);
void invoke2(void (Class::* pmf)(Args...),
typename identity<Args>::type... args)
void invoke3(void (Class::* pmf)(Args...),
typename std::remove_reference<
typename std::remove_const<Args>::type
>::type const&... args)
struct Proxy
: public invoker<T>
Proxy(T& t)
: invoker<T>(t)
void foo(int x)
this->invoke1(&T::foo, x); // works fine
int main()
A a;
Proxy<A> b(a);
b.foo(5);
invoke3(...) is what I have in my codebase. invoke2(...) is a simplification I'd certainly expect to work here.
Is this a known issue (I know variadics are new in Intel)? If not, can this please be added as a bug ticket.
--Nathan
