Intel® C++ Compiler
7782 Discussions
bug: warning #469 is hidden when function overloaded
Sergey_K_3
When compiling example below, you will get warning:
#469: temporary used for initial value of reference to non-const (anachronism)
and when another overload is added (see comment) warning disappears, but compiler still choose "BOOL" overload instead of "OBJECT". Note that disabling microsoft extensions (/Za) brings warning back.
We are using x64 compiler for visual studio 2013, version 15.0.1.148 build 20141023 on windows 7.
#include <iostream>
struct T {};
struct P { P(T*) {} };
void f(bool&) { std::cout << "BOOL" << std::endl; }
//uncomment this function to hide compilation warning
//void f(P) { std::cout << "OBJECT" << std::endl; }
int main() {
  	f(new T);
  	return 0;
Sergey_K_3
I have, another question. Is it possible to disable initialization of non const references from temporary object with microsoft extensions enabled and overloaded function? We want to drop /Za option and make compiler behave like /Qdiag-error:469 is enabled end warning remains.
Judith_W_Intel
Regarding the first question -- we actually emit a slightly different diagnostic for when the overload is declared which can only be seen with the /W5 option or if it is explicitly requested, i.e.:
74% icl -c /Qdiag-warning:504 bug.cpp
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Ve
rsion 15.0 Beta Build x
Built Mar 11 2015 14:01:59 by jward4 on JWARD4-DESK1 in D:/workspaces/15_0cfe/de
v
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
bug.cpp
bug.cpp(13): warning #504: initial value of reference to non-const must be an lvalue
    f(new T);
75%
We try to be warning for warning compatible with Microsoft and in the case of the overload Microsoft does not emit any diagnostic so we do not either.
For the second question -- if you use /Qdiag-error:504 and /Qdiag-error:469 then both examples with get an error even without the /Za option.
Judy
