Intel® C++ Compiler
build and compilation Problem (icc)
Swapnil_J_
Hello Friends,
         I am trying to read and execute intel compiler tutorial and some sample code. but when i trying to execute following command i got error.
root@swapnil-lp:/opt/intel/composer_xe_2013/Samples/en_US/C++/mic_samples/LEO_tutorial# icc -openmp tbo_sort.c -o tbo_exe_MIC
icc: warning #10361: Environment configuration problem encountered.  Please check for proper MPSS installation and environment setup.
tbo_sort.c(29): catastrophic error: *MIC* cannot open source file "stdio.h"
  #include <stdio.h>
compilation aborted for tbo_sort.c (code 4)
if i comment to all header file i got following error.
x86_64-k1om-linux-ld: No such file or directory
I have set compiler / enviornment variable:
using following command :
$ source compilervars.sh intel64
What is problem there? Is it insallation problem or envoirnemnt variable problem?
when i have installed it gives folowing message at time of installation
Step no: 6 of 7 | Installation
Each component will be installed individually. If you cancel the installation,
components that have been completely installed will remain on your system. This
installation may take several minutes, depending on your system and the options
you selected.
Installing Amplifier XE Command line interface component...
ERROR: Package is corrupted. Installation cannot continue.
Installing Inspector XE Command line interface component...
Installing Advisor XE Command line interface component...
Installing Intel C++ Compiler XE 13.0 Update 1 on IA-32 component... failed
Installing Intel C++ Compiler XE 13.0 Update 1 on Intel(R) 64 component... done
Installing Intel Debugger 13.0 Update 1 on IA-32 component... failed
Installing Intel Debugger 13.0 Update 1 on Intel(R) 64 component... done
Installing Intel Math Kernel Library 11.0 Update 1 on IA-32 component... failed
Installing Intel Math Kernel Library 11.0 Update 1 on Intel(R) 64 component... done
Installing Intel Integrated Performance Primitives 7.1 Update 1 on IA-32
component... failed
Installing Intel Integrated Performance Primitives 7.1 Update 1 on Intel(R) 64
component... done
Installing Intel Threading Building Blocks 4.1 Update 1 core files and examples
component... done
Finalizing installation... done
Step no: 7 of 7 | Complete
Thank you for installing and using the
Intel(R) C++ Studio XE 2013 Update 1 for Linux*
Reminder: Intel(R) VTune(TM) Amplifier XE users must be members of the "vtune"
permissions group in order to use Event-based Sampling.
To register your product purchase, visit
https://registrationcenter.intel.com/RegCenter/registerexpress.aspx?clientsn=NSW
P-J64NKNPZ
To get started using Intel(R) VTune(TM) Amplifier XE 2013 Update 2:
    - To set your environment variables: source
/opt/intel/vtune_amplifier_xe_2013/amplxe-vars.sh
    - To start the graphical user interface: amplxe-gui
    - To use the command-line interface: amplxe-cl
    - For more getting started resources: /opt/intel/vtune_amplifier_xe_2013/
      documentation/en/welcomepage/get_started.html.
To get started using Intel(R) Inspector XE 2013 Update 2:
/opt/intel/inspector_xe_2013/inspxe-vars.sh
    - To start the graphical user interface: inspxe-gui
    - To use the command-line interface: inspxe-cl
    - For more getting started resources: /opt/intel/inspector_xe_2013/
To get started using Intel(R) Advisor XE 2013 Update 1:
/opt/intel/advisor_xe_2013/advixe-vars.sh
    - To start the graphical user interface: advixe-gui
    - To use the command-line interface: advixe-cl
    - For more getting started resources: /opt/intel/advisor_xe_2013/
To get started using Intel(R) Composer XE 2013 Update 1 for Linux*:
    - Set the environment variables for a terminal window using one of the
      following (replace "intel64" with "ia32" if you are using a 32-bit
      platform).
      For csh/tcsh:
           $ source /opt/intel/bin/compilervars.csh intel64
      For bash:
           $ source /opt/intel/bin/compilervars.sh intel64
      To invoke the installed compilers:
           For C++: icpc
           For C: icc
      To get help, append the -help option or precede with the man command.
           /opt/intel/composer_xe_2013/Documentation/en_US/get_started_lc.htm.
To view movies and additional training, visit
http://www.intel.com/software/products.
q. Quit [default]
Please type a selection or press "Enter" to accept default choice :
Swapnil_J_
Error 2 : I have write Matrix multiplication program. using following command I got some error. root@swapnil-lp:/opt/xe_composer# icc -02 MatrixMulti.c icc: command line warning #10006: ignoring unknown option '-02' If i execute following command then it executed: root@swapnil-lp:/opt/xe_composer# icc MatrixMulti.c root@swapnil-lp:/opt/xe_composer#
Alexander_W_Intel
Hi, you used the number 0 (zero) instead of the letter O :-) Alex
Swapnil_J_
Hi Alexander, ok just forget this error for some time but for my above problem is not using any numbre how will i solve this. What is meaning of -o gcc -o2 MatrixMulti.c -o MatrixMulti_gcc_o2 Please tell me meaning of -o2
TimP
If your problem relates to learning how to install the compile tools for Intel(c) Xeon Phi(tm) you might do better to post on the appropriate forum. There is an option to download the KNC libraries associated with your compiler at https://registrationcenter.intel.com in case you don't have the co-processor card and are simply trying to cross-compile. If you insist on being so selective about reading answers, I will be replying to your posts only in the hope that others may read. The compiler would likely take -o2 as a -o option, but your second -o option should over-ride the first.
Alexander_W_Intel
I think you wanted to write: gcc -O2 MatrixMulti.c -o MatrixMulti_gcc_o2 The difference is the capital -O2 instead of a lower case one you used. The capital -O specifies the optimization level. The lower case -o specifies the output file name. If you not specify the the output file name, the compiler will generate a file with the name "a.out". If you want to know more about compiler parameters for the Intel® C++ Compiler please have a look in the documentation: http://software.intel.com/sites/products/documentation/doclib/stdxe/2013/composerxe/compiler/cpp-lin/index.htm Thanks, Alex
Swapnil_J_
Thanks Alexander, Now i am getting. Now I will check performance diffrence of each optimization level.
