Hello Friends,
I am trying to read and execute intel compiler tutorial and some sample code. but when i trying to execute following command i got error.
root@swapnil-lp:/opt/intel/composer_xe_2013/Samples/en_US/C++/mic_samples/LEO_tutorial# icc -openmp tbo_sort.c -o tbo_exe_MIC
icc: warning #10361: Environment configuration problem encountered. Please check for proper MPSS installation and environment setup.
tbo_sort.c(29): catastrophic error: *MIC* cannot open source file "stdio.h"
#include <stdio.h>
compilation aborted for tbo_sort.c (code 4)
if i comment to all header file i got following error.
x86_64-k1om-linux-ld: No such file or directory
I have set compiler / enviornment variable:
using following command :
$ source compilervars.sh intel64
What is problem there? Is it insallation problem or envoirnemnt variable problem?
when i have installed it gives folowing message at time of installation
Step no: 6 of 7 | Installation
Each component will be installed individually. If you cancel the installation,
components that have been completely installed will remain on your system. This
installation may take several minutes, depending on your system and the options
you selected.
Installing Amplifier XE Command line interface component...
ERROR: Package is corrupted. Installation cannot continue.
Installing Inspector XE Command line interface component...
Installing Advisor XE Command line interface component...
Installing Intel C++ Compiler XE 13.0 Update 1 on IA-32 component... failed
Installing Intel C++ Compiler XE 13.0 Update 1 on Intel(R) 64 component... done
Installing Intel Debugger 13.0 Update 1 on IA-32 component... failed
Installing Intel Debugger 13.0 Update 1 on Intel(R) 64 component... done
Installing Intel Math Kernel Library 11.0 Update 1 on IA-32 component... failed
Installing Intel Math Kernel Library 11.0 Update 1 on Intel(R) 64 component... done
Installing Intel Integrated Performance Primitives 7.1 Update 1 on IA-32
component... failed
Installing Intel Integrated Performance Primitives 7.1 Update 1 on Intel(R) 64
component... done
Installing Intel Threading Building Blocks 4.1 Update 1 core files and examples
component... done
Finalizing installation... done
Step no: 7 of 7 | Complete
Thank you for installing and using the
Intel(R) C++ Studio XE 2013 Update 1 for Linux*
Reminder: Intel(R) VTune(TM) Amplifier XE users must be members of the "vtune"
permissions group in order to use Event-based Sampling.
To register your product purchase, visit
https://registrationcenter.intel.com/RegCenter/registerexpress.aspx?clientsn=NSW
P-J64NKNPZ
To get started using Intel(R) VTune(TM) Amplifier XE 2013 Update 2:
- To set your environment variables: source
/opt/intel/vtune_amplifier_xe_2013/amplxe-vars.sh
- To start the graphical user interface: amplxe-gui
- To use the command-line interface: amplxe-cl
- For more getting started resources: /opt/intel/vtune_amplifier_xe_2013/
documentation/en/welcomepage/get_started.html.
To get started using Intel(R) Inspector XE 2013 Update 2:
/opt/intel/inspector_xe_2013/inspxe-vars.sh
- To start the graphical user interface: inspxe-gui
- To use the command-line interface: inspxe-cl
- For more getting started resources: /opt/intel/inspector_xe_2013/
To get started using Intel(R) Advisor XE 2013 Update 1:
/opt/intel/advisor_xe_2013/advixe-vars.sh
- To start the graphical user interface: advixe-gui
- To use the command-line interface: advixe-cl
- For more getting started resources: /opt/intel/advisor_xe_2013/
To get started using Intel(R) Composer XE 2013 Update 1 for Linux*:
- Set the environment variables for a terminal window using one of the
following (replace "intel64" with "ia32" if you are using a 32-bit
platform).
For csh/tcsh:
$ source /opt/intel/bin/compilervars.csh intel64
For bash:
$ source /opt/intel/bin/compilervars.sh intel64
To invoke the installed compilers:
For C++: icpc
For C: icc
To get help, append the -help option or precede with the man command.
/opt/intel/composer_xe_2013/Documentation/en_US/get_started_lc.htm.
To view movies and additional training, visit
http://www.intel.com/software/products.
q. Quit [default]
Please type a selection or press "Enter" to accept default choice :
